hi every body i have a big problem in my work and i think it will be solved by your helping,
i want from any one to tell me what is the different between flange according to ANSI B16.5 and Din 2636
because the dimension in the ANSI B16.5 class 400 ( PN68) says the thickness of the flange is 12.7 mm and the DIN 3636 (relating pressure 64) says the thickness of the flange is 7.1 mm ,if the ANSI B16.5 class 400 ( PN68) is equal to DIN 3636 (relating pressure 64) so why there is diferent in the thickness and if not equal, what is the relation between them.
thanks so much
