Previous in Forum: allowed voltage drop/gain on 415volts system   Next in Forum: DC MACHINE, SPEED CONTROL CALCULATION
Harrison Ampl
01/17/2010 7:08 AM
Replacement: For a Harrison Amp replacement 4x Elect Caps 10,000 mF -100V. diam 64 mm x h 45 mm. manufactured by LCR UK. Its hard to find that capacitors like this dimensions. Any help is welcome
Re: Harrison Ampl
01/17/2010 8:38 AM
Are you sure about the dimensions? 10,000μF @ 100V is typically 3 times that volume.
Re: Harrison Ampl
01/18/2010 8:34 AM
@ JohnDG: Yes, there are 4 Capacitors at that dimensions in the Harrison K3000 amp.
I like to send you a picture of this item, please send a e-mail to me b.westermar@inter.nl.net
thanks
Good Answers: 16
Re: Harrison Ampl
01/19/2010 10:41 AM
Panasonic makes a cap, 50 mm x 50 mm stocked at Digi-Key in the U.S.A.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=P13285-ND
None of the links to LCR seem to be active although I cannot find any indication that they are out of business.
Hope this is close enough to work for you.
Re: Harrison Ampl
01/22/2010 4:36 AM
I will thank you for your help! At this time we will investigate the Panasonic solution from Digi Key in the USA.
'till next time'
L.Jongema
Register to Reply 4 comments
Electronic Wiz (1); JohnDG (1); ljongema (2)
