Previous in Forum: Harrison Ampl   Next in Forum: Problem with CAT generator ECM
DC MACHINE, SPEED CONTROL CALCULATION
01/17/2010 7:56 AM
Hi guys please help.
I am busy with speed control calculation on the DC(direct current) Machine.
QUESTION
A SERIES MOTOR IS FED FROM A 500V SUPPLY AND TURNS AT 800r/min at full load, while the current taken is 120A. THE FIELD AND THE ARMATURE RESISTANCES ARE 0,04 OHM AND 0.11 OHM RESPECTIVELY. IF IT IS ASSUMED THAT THE FIELD IS UNSATURATED, CALCULATE: THE SPEED WHEN THE TORQUE HAS 50% OF ITS FULL-LOAD VALUE, WHILE THE APPLIED VOLTAGE IS 500V AND A RESISTANCE OF 0.08 OHM IS CONNECTED IN PARRALLEL WITH THE FIELD. (ANSWER 1397 r/min)
Dan Segami
Good Answers: 804
Re: DC MACHINE, SPEED CONTROL CALCULATION
01/17/2010 12:39 PM
www.doyourhomeworkyourself.com
01/17/2010 3:05 PM
@JRAEF: PLEASE HELP I TRIED
Dan Segami
Register to Reply 2 comments
