Previous in Forum: Main Tie Main Configuration   Next in Forum: Wire Schematic for Garrett Ground Hog ADS Metal Detector
Earth fault & restricted earth fault
01/17/2010 11:44 AM
What is the difference between earth fault & restricted earth fault?
Please explain.
Re: Earth fault & restricted earth fault
01/17/2010 8:14 PM
Good Answers: 170
01/18/2010 9:00 AM
(Plain) Earth fault protection scheme would respond for any earth fault current beyond the setting, irrespective of the location of the fault in the network. Whereas, restricted earth fault protection scheme, as the name suggests, would respond only to those earth faults, which are happening in a pre-defined zone of protection. If the earth fault is outside this zone, even if the fault curent is more than the setting, the scheme wouldn't respond.
Register to Reply 2 comments
