Previous in Forum: Curvilinear Gear   Next in Forum: Replacing Larger Car Tires With Smaller Ones
24 comments
Slow Cranking Flathead
01/18/2010 12:34 PM
While crsnking to start my 6 volt truck ( flat head six) with batter fully charged and truck always in heated garage on my third short crank to start the engine I heard a arc or short occur and lost everything, no lights, horn, absoutely nothing, check battery it good, still fully charged. I believe ther may be a overload breaker on the firewall very low behind the battery, looks like ceramic with heavy gage wires to it, but thought it might also be the starting solenoid relay that was cooked, I have not tested anything yet but will start by checking for 6 volts to the starter off the relay with the key in on position and depressing the start button, from there I will look for circuit breakers under the dash. any additional advise will be appreciated.
Getting to the point where I will look for a shop to convert the system to 12 volts
this may help with the slow cranking of the engine any thoughts?
Pathfinder Tags: slow cranking burnout
Re: slow cranking flathead
01/18/2010 12:42 PM
It would help a lot if we knew the make and model of the vehicle and where on the planet you are.
Can't really help you till you give us at least a little more information.
I'll take a stab at the second question: Local Yellow Pages. Automotive electric shop.
01/18/2010 3:05 PM
Battery is fairly new checked charge is 100%, the cable from the starting solenoid looks original with minor cloths fretting on the sides, cant tell the age of the solenoid,
system was converted to neg ground but not by me.
while cranking I could not determine if the arc I heard was in the cab or outside under the hood I had the hood up.
The vehicle is a 1948 ford F1 with alot of the original wiring still installed.
I plan on checking for voltage between to solenoid post from the battery to the starter side of the solenoid while the key is in the on position and then also pushing the start button while reading the volt meter.
otherwise I will look at the porcelain block behind and under the battery support, it may be the fusible link that may have burned.
01/19/2010 12:08 AM
Basically the slow cranking related apart from the terminal voltage of the battery, it is related to the Specific Gravity of the battery which should be a minimum of 1220.The battery should be inspected for the SG with a suitable Hydro meter.Not necessasry if the voltage is showing full and the SG need to be upto the satisfactory level. Due to internal resistance of the battery such as sulfation and buckling etc.like battery interal problems the battery cannot deliver enough power to crank the engine upto the firing speed. It is threfore advised to check the SG of the each cell of the battery.
Thank U
CVS Murthy
01/18/2010 1:35 PM
A common problem is corrosion between the battery posts and the cable lugs them selves or between any points that carry the high current from or back to the battery. Usually its a bad cable or other connection in the high current carrying circuit. Occasionally it can be that the starter itself is loose and not making a connection back to the ground lead which is most often attached to the engine.
As far as I have ever known there where no circuit breakers ever put on starting circuits. They need the least amount of resistance and can carry many hundreds of amps of current which tends to rule out the want or need for any type of over current protection.
If you have to do a starter circuit rework its also a good time to consider the 12 volt conversion being you are already about 1/3 of the cost into having it done. Whenever I replace any battery cables or connection components I always go over kill on the cable sizing. Where I live just stepping up from factory 4 gauge cables to aftermarket 1/0 gauge is the difference between barely starting at 0 F and starting well at -25 F!
Good Answers: 145
Re: Slow Cranking Flathead
01/18/2010 7:30 PM
If I may add my 2cents worth.
It might be time to give the Ol' girl a birthday, and start replacing some of the "tired" wiring. Wiring does get old and becomes resistive, especially when dealing with high DC currents.
I concur that cleanliness of battery terminations are very important on 6volt systems. The arc noise you heard was probably the electrons trying to find a way through the resistance created by verdigris and corrosion on the terminals associated with the starting circuit.
If you want to retain the 6 volt electrics then you will have to go through and clean up or replace all the terminations. As well as replacing the cables.
It will help if to have a suitable heavy cable/strap from the engine to the Chassis/battery. The Solenoid may have burnt contacts from cranking the motor for the past 60years, time for a new one. That may be problematic as I haven't seen any new 6 volt ones for years. But I'm sure there are speciality shops in the U.S. that do re-pro stuff.
The thing with 6 volt systems is that it doesn't take much to stop it working because of the high (proportionately)current at the low voltage used to do anything and any resistance becomes an issue. Which means Ohms law (and Murphy's for that matter) works overtime. Cable size is critical, what is choice for a 12Volt system is not adequate for a 6volt system.
Conversion to 12volt is easy in so far as there is quite a lot of conversion stuff available from later model flathead fords in the way of generators, wiper motors, etc.
I did a 6/12volt conversion on a "51 Chev ute, and that was pretty painless (except the change from left to right hand drive and the owners insistence of using a preformed wiring harness for LHD!)I also converted a 58 VW Kombi from 6 to 12volt, afterwards it started first time everytime and I could see with the headlights at night.
As a thought that "ceramic" thing may be a ballast resistor for the coil and it will have heavyish wires going to and from it and be connected to the starter solenoid so it gets bypassed during starting.
Hope that helps.
Good Answers: 196
01/18/2010 11:43 PM
GA to both you and tcmtech.
I've had many years experience with 6V Fords. It's been my observation that the Ford starters and solenoids are quite robust and don't fail very often. That snap you heard was several hundred amps trying to break through the dirt in one of the main current connections. Start there. Clean everything until the metal is shiny and when you put it back together put a thin film of light grease like white Lubriplate on the contacting surfaces before you tighten the connection. Don't forget the grounding connections. In most cars there are at least 6 of them between the battery post and the starter housing.
I never had a problem with a flathead where the starter housing wouldn't ground to the engine (usually the oil pan on those old machines.) I think the reason is that those old engines always accumulate a thin film of oil in the lower part of the engine compartment. Not so in modern cars and sure enough I had a problem of bad contact between the engine and bell housing in an 1993 E350 Ford 460 engine.
Worthy of note here is that exposure of the vehicle to salty roads can create all kinds of electrical contact mischief in a vehicle. I had this problem with my 2000 Toyota Tacoma 4 cyl with the main cable connection to the starter solenoid. The fix included a liberal application of my Lubriplate treatment.
If you are going to try and test resistance that must be done at full current flow (i.e. with the starter cranking) for it to mean anything. You'll almost certainly need a helper. And whoever holds the meter should wear eye protection. That snap you heard is a substantial release of mechanical energy.
Another test is to touch with a finger the connection just after opening the circuit. If it is hotter to the touch than other starter connections you've likely found your culprit. This is an excellent test for emergencies on the road. Also good for checking ignition and charging circuits where bad contact is suspected.
Personally I'd clean all the connections first.
Ed Weldon
Good Answers: 213
01/19/2010 12:51 AM
"Heard a ark or short occur and lost everything..."
Lots of juice going to ground somewhere. Most likely, there will be a burned wire where this happened. Good chance of ozone odor as well, if the engine compartment is clean enough.
Since you lost everything, not just the starter circuit, the problem area is going to be close (electrically) to the battery. Trace positive wire from the battery, check voltage at each connection with respect to ground. It seems unlikely that a fried starter solenoid would cause you to lose your lights and horn, since it is only in circuit when the starter button is pressed. The ceramic-looking thing with heavy gage wires going to it- is one of the wires connected directly to the battery terminal? If so, you most likely should have 6 volts on both sides of this device...
If the battery is not discharging over night, then you have an open circuit somewhere. If the battery will not hold a charge overnight (assuming it is good), then you most likely have a ground fault somewhere. An open circuit can be much easier to find than a ground fault...
01/19/2010 1:47 AM
if you find what burned out and it works use a 8volt battey are use a 12 to 6 converter from your 12 battery to all the small wires that was on battery hot post truck for lights and your dash put new battery and charging system run hot from charge wire strat to battery 12 and get the 12 volt starter if you do it right all lights and dash will work on 6 volt just starter and charging system and your battery will be 12 volt
I use the 8 volt battery on my 6 volt vw it works great its been like that from 1982 on all is still a 6 volt system and it spin better like this
01/19/2010 7:56 AM
From Tim Hawley Master Mech.
A 6 volt system is ok.
First disconnect the battery cables. Check continuity cross your fuse breaker. If there is no resistance replace with new. Do not try the starter after replacement, this will only cause the breaker to fail again. There is an other component that is pulling a heavy current load. Remove starter and take it to a local starter rebuild facility. There are a few still in the detroit area that rebuid 6 volt starters and generators. Have it inspected. The starter solenoid may be damaged as well.
It can be checked using a 6 volt battery charger or the local starter rebuild facility should be able to check it for a small fee. Some battery chargers can be purchased with a 6 or 12 volt output switching circuit.
Solenoid Test:
Ground the negitive terminal from the power source to the solenoid metal support.
Connect the positive to the original battery lug. Turn on the power source on and check the voltage output of the feed wire originally connected to the starter. If there is 6 volts output the solenoid is most likely good and was not damaged during the starter current over load.
Good luck
01/19/2010 7:49 PM
Since the arc noise occcured while cranking, and then everything went dead, check for a broken, loose,or corroded ground connection from frame to engine,and from battery to engine/frame.If all cables are new and clean and connections are tight, physcially trace the positive wire to the starter, and inspect the full length.You will probably find a loose or broken connection.Do the same with the ground wire.Make sure the ground wire is at least a #6 guage or larger, and is connected mechanically close to the starter, for this is your largest load on the system.Sounds like the heavy current from the starter burned through a small conductor ground from engine to frame or to battery.
01/19/2010 7:50 PM
I've converted many an old Ford. I'm betting your starter solenoid just popped. If you have trouble locating 6 volt parts, Speedway Motors in Lincoln Nebraska has Flathead parts (even a 6volt alternator). You have a great opportunity here to convert to 12volt if that is the direction you plan to go. I'm driving a '53 F100 that I converted over. It still has the 6volt starter in it. It starts everytime (even in the -11 degree temps we just had) You just don't want to crank on it for long intervals. I just changed all of the lites, (headlights, dash and tail lites) changed to a 1wire 12v alternator, installed a 12volt horn relay (56 and up Fords) and a "Runtz" voltage reducer (from www.SpeedwayMotors.com ) part#910-64101 for the gauges. Good Luck with your project!
01/20/2010 6:38 AM
thanks much, I am going to convert to 12 volt plus rewire the old girl!
01/20/2010 12:42 PM
Drop me an e-mail if you ever need any old ford parts. Or if your looking for info on old Fords. I'd rather drive one of my all steel rigs than the plastic ones they make today. rwalters@southslope.net
01/21/2010 8:19 AM
It will not be factory and will be worth less money
It's you choice.
Good Answers: 196
01/21/2010 5:02 PM
Tim -- I can't tell what part of the country you are from; but in most places in the US that I'm familiar with an old 6 cylinder Ford truck of any kind better be in pristine near museum condition to have its value diminished by a 12 volt conversion that is anywhere near being neatly done. Like don't torch a hole in the firewall to fit a different battery in.
In his later post the OP mentions some modifications to wiring under the dash. That alone could easily knock a couple of thou. off the value of a museum piece. I don't think that is what we're dealing with here.
Frankly, I wouldn't discourage Flaresideone in doing the 12 volt conversion if he feels good about doing the work and investing in a new charging system. In the years around 1949-50 Ford went from wide v-belts to narrow v-belts on the engine accessories. Implementation on trucks and industrial engines was pretty scattered and just knowing the model is no guarantee. His 48 truck could have had a later year engine put in it. If it has wide belts then finding an alternator to fit might get pricey.
I know Flathead V-8's pretty well but not so the sixes. Back in my archives I do have a dandy little "H" model 6 that came out of a 67,000 mile 48 pickup a few years ago and is slated for a future rat rod project. It has an OEM looking alternator on it and the whole setup uses a 7/8 inch wide belt. Mine could be a real oddball. When I got it I figured I'd just deal with it later and paid little attention. Examples of oddball pulley setups abound on truck and industrial engines.
The one thing I'd like to mention here is that before hitting the truck's system with 12 volts or even 8 volts he should check the headlights and make sure they are not connected. If the truck has an original factory 6 volt sealed beam headlight, the one without the 3 little nubbins that the modern headlight aiming tools rest on, then the sealed beam itself may have some collector value. These lights are really rare these days. The same goes for an original 6 volt factory radio, although most trucks didn't have such luxuries in those days.
Ed Weldon
01/21/2010 6:15 PM
To: Tom Weldon,
Excellent points you are making. In order to keep the vintage look as far as the head lamps, blinkers, tail-light's radio Instrument panel and so on... all of the bulbs and sockets must be compatible to a 12 volt system. Also the original alternator, sorry generator will have to be replaced with a solid-state alternator. Also to switch over from start to run regulator field circuit has to be thought out as well. The ignition coil will require replacement and distributor points and spark plugs should be upgraded as well.
The more money and changes that are made, the less value the vintage vehicle is worth on the market if the vintage look is not maintained.
Best Regards
Good Answers: 196
01/21/2010 8:03 PM
"The more money and changes that are made, the less value the vintage vehicle is worth on the market if the vintage look is not maintained."
Sorry Tim. That may be true for American cars of 55-72, especially the muscle cars, and foreign exotics (a high profile racing pedigree can trump even that).
It is patently false in the North American market for Fords vintage 1928 through 1951 and mostly so through 1956, especially light trucks. This assumes, of course, that the workmanship in making changes is up to professional and customizing is reasonably conservative. One need only look at the street rod market to see that. Few if any of the most perfect restorations can bring the high 5 and even low 6 figure prices that many well done street rods havce been fetching.
Our OP's truck is right in the middle of that early Ford group. By and large antique pickups of these vintages see more current everyday utility use than comparable passenger cars. As such the addition of improved mechanical components does even more to increase their value than they would for a comparable passenger car.
Ed Weldon
01/22/2010 3:36 PM
To: Ed Weldon, Sorry I put Tom Weldon instead of Ed.
Best Regards
Good Answers: 123
01/20/2010 9:06 PM
There is NO circuit breaker in the starter circuit. Put that to rest now.
You have gotten some good answers already, Please allow me to try to walk you through the testing. Get a digital voltmeter. An analog will just make it harder to see the voltage drops you need to find. The voltage is stored in the battery, start your testing there. Read the voltage across the battery ONLY. Not the cables, not the wires, directly on the battery posts. Now have an assistant hit the starter. Does the voltage drop to "0"? if so, the battery has a faulty connection, and needs to be new.
If the battery voltage does not move, start to move away from the battery. Now move the voltmeter to the negative post on the battery cable. Has the voltage gone away? If voltage is there, go to the other end of the negative cable. That should be the starter solenoid. (positive ground in these older Fords) Test the lug of the battery cable, then the post of the solenoid.
If the voltage has remained this far, it is time to go to the ground side. Again move the tester lead to the positive terminal of the battery cable. Next test the other end of the positive cable. That should be on the engine itself. Lastly test the engine itself.
Follow the advice and buy 1-0 gauge battery, starter, and ground cables. The cables are the current carrying devices that allow the starter to work. You can now breath enough air through a straw. Likewise, you can not run a starter motor with thin starter cables.
By now you should have found your problem. My guess is the connections at the battery. Good luck. Remember, if it ain't broke, don't try to fix it. That 6 volt system worked well on hundreds of thousands of these Fords. It will work if you allow it to.
Bob
Good Answers: 196
01/20/2010 10:31 PM
GA Bob -- In most cases this diagnostic would catch a problem. But there is a subtle clue in the OP that suggests the general approach I suggested before but didn't explain very well. The audible snap is a sure clue to a conductive path with too much resistance and some tendency to misbehave intermitantly.
I believe the right test is to measure voltage drops as you suggested (not resistance like I mentioned before) at each connection WITH THE ENGINE CRANKING AND FULL CURRENT FLOWING THROUGH THE CONNECTION. Resistance is tough to measure at low fractions of an ohm even with a high quality DVM. A 1 or 1-1/2 volt drop at several hundred amps is a lot of "juice" lost. You can catch that with the cheapest analog meter if that's all you have.
Side note here if you don't have a voltmeter; if you wire up a small 6 volt bulb and socket with a couple of wires and contact probes you can use that to check voltage drops down to maybe 1-1/2 or 2 volts at which point the filament in the bulb will be barely glowing. Set this little test lamp up and calibrate your eyes and brain with a stack of flashlight batteries to test it at increments 1-1/2 volts, 3 volts and 4-1/2 volts. This tool and some understanding of basic automotive electrical circuits will give you a great "on the road" diagnostic capability. Put your bulb and socket inside a small clear plastic protective container, seal the wires with some silicone caulk and it will be ready to bounce around in the glove box or trunk.
You can also do this with 12 volt bulbs for later model vehicles although the technique is less useful with all the contacts buried in modern insulated electrical connectors.
As another suggested if the trouble is at the contacts inside that old Ford solenoid or within the starter itself cleaning the contact surfaces won't be so easy.
If that old Ford starter solenoid is the one with the manual push button on the top and it's still OK by all means keep it. Even if you convert to 12 volts. Not having to go around the door to hit a starter button in the dashboard while doing a tuneup is a very nice convenience. On the other hand if the solenoid has been getting rained on for a few years there could be corrosion on the contacts inside. That's the downside of that old design.
Ed Weldon
01/21/2010 6:52 AM
Ed:
I also thought of using a spare 6 volt bulb which I plan on making up, due to the system being totally out I cannot crank the engine at this time.
Also looking into rewiring the whole truck.
Looking under the dash I found several circuits were rewired with in-line fuses, after checking all the elements I will start with current across the solenoid, this truck has been in a garage for many years and other than a little rust down on the frame and one spot on the floor board the contacts look pretty clean.
Thanks
Flaresideone
Mike
Good Answers: 123
01/21/2010 9:57 AM
Thanks. I have not seen the light bulb used that way in years. An old boss used to use 12 volt bulbs on 6 volt systems, and 24 volt on 12. He said it was easier on the eyes to see differences. I had not thought about him in a long time. I sure miss him.
Bob
01/22/2010 10:35 AM
To all
I am talking to Ron Francis wiring harness company to go over the correct way to convert to 12 volt. the truck is not a show piece but I want to enjoy the ability to open the garage and know it will start, the state of Pennsylvania's registration review approved it for antique and they can be tuff, yes its all original lights, tail lights working radio etc. And Ron Francis company is five minutes from where I work.
Hopefully next couple of weeks when I finish installing the master cylinder and bleeding the brakes I will start to investigate the starting issues, I greatly appreciate all the input because the electrical side of things is my weaknees.
Thanks again
Mike( flaresideone)
Good Answers: 123
01/24/2010 1:14 AM
Although I have never dealt with Ron Francis, they seem to be very well liked in the world of Hot Rods, and Street Rods. They will probably pinpoint your problem for you, if you can get it to them.
Bob
Register to Reply 24 comments
Anonymous Poster (3); bob c (3); cwarner7_11 (1); Ed Weldon (4); flaresideone (4); Hot_Rodg (2); lyn (1); tcmtech (1); Tim Hawley Master Mech (4); Tobugrynbak (1)
