Previous in Forum: vehicle power calculation   Next in Forum: Slow Cranking Flathead
Curvilinear Gear
01/17/2010 4:04 PM
I have a patent pending on a new gear concept, the curvilinear gear. I am a mechanical engineer that is now retired, at least financially. I still am an enthusiastic participant in developing mechanical engineering concepts and products. Two years ago, I challenged myself to either improve or replace a basic mechanical engineeringg concept.
I chose the gear. I chose this design concept because it is over 5000 years old. I asked myself, how could things remain so static, given the advances made in material and manufacturing technologies, to the basic gear design concept. One thing I noted was that gears are basically a 2-D concept. This is what caused me to look into this technology more. I asked, "What if we went 3-D with this technology". Which means, "What if we could could change the radius of a gear head we moved across the width of the gear head"?. As I thought about this concept, it became clear that there might be some major advantages to doing this. The most important advantage being that one gear set could potentially replace multiple gear sets. When I investigated this further, I learned that some people had already asked the same quaestion, the most important being Leonardo DiVince. Over 500 yars ago, Leonardo asked this question and answered it by coming up with the idea of a CVT (Continuously Variable Transmission). He did run into a problem, he could not figure out how to directly drive a CVT. The problem he ran into is that mechanical engineering had not progressed far enough for him to take advantage of. Leonardo was truely a revolutionary thinker who goes way beyond some of us who try to walk in his foot steps. But his idea survives even today as many companies try to figure out how to improve the application of CVTs to current needs. Lubrication and electromechanical concepts seem to be the direction mos are taking. I have decied t take a different approach.My approach is a "direct drive" CVT.
In 1984, AGMA pubished a stratic plan for the gear industry. The first thing they did was to acknowledge they are not a gear industry, but rather, a power train industry. This is a very important change in thinking. Why is it important? It is important because my concept shows how the current gear industry can compete and actually beat its current challengers.
What I have developed is a direct drive power train that is driven using basic gear concepts.
If anyone has an interest in discussing this concept, I woud be glad to engage in any reasonable discussion...
Re: Curvilinear Gear
01/17/2010 4:30 PM
Unless you would be giving away proprietary information, it would be interesting to see your concept.
Gears are generally conceived as having a fixed integral number of teeth. Beveled gears, in which the radius changes across the tooth width, still maintain a fixed ratio.
I once made a demonstration set of elliptical gears, whose ratio varied over the course of one revolution, but was (necessarily) 1:1 overall.
Two types of CVTs I know of are 1) variable sheave pulleys, as in snowmobiles, and 2) a conical drive disk that engages a friction follower roller (e.g., SEW Eurodrive). I forget the details, but I once saw a concept based on friction-contact paraboloids of revolution that could be slid so the smaller part of one would engage the larger part of the other, and vice versa.
Hypoid gears, to pick one example, are not exactly a 2D concept....
I think it is more common to vary the speed of the prime mover, as with a VFD on an electric motor, or a flow control valve on a hydraulic motor.
That said, new concepts will be interesting.
01/19/2010 5:27 AM
The best way to introduce you to my concept is to send you a couple of brochures. I would be glad to do so if you give me your email address. Send it to me at ljb@shore.net and/or post it here...
Good Answers: 123
01/17/2010 10:27 PM
I as is Tornado is am intrigued by your ideas. I also thing of hypoid gears as 3D.
There was variable ratio steering gear that was designed by the steering gear people at GM. It was first used in the late sixties. The teeth on the box were closer together on center than they were off center. Have you looked into that yet? I just recently read where one of the US manufacturers was working with variable ratio rocker arms on gasoline engines. Try doing a search on that subject. Good luck, and we are hoping for some pictures.
Bob
01/19/2010 5:32 AM
I can send you a couple of brochures if you give me your email address... Send it to me at ljb@shore.net and/or post it here... Also can you tell me where I might find information on the GM applications you mentioned in your comment?... Thanx....
Good Answers: 123
01/19/2010 9:33 AM
Rather than posting e-mail addresses on this forum, you can send personnel messages threw the CR4 forum. If you register with CR4, they will forward any mail sent to them to you. Below is a site that gives the basics of the GM variable ratio steering box.
http://www.carcraft.com/techarticles/ccrp_0901_gm_steering_box_upgrade/internal_box_modifications.html
Bob
01/19/2010 8:43 PM
Take the trouble to sign up, send us the information and we will take the trouble to read it.
Cheers.
Good Answers: 247
01/21/2010 1:44 AM
You might be interested in this thread.
Anonymous Poster (2); Blink (1); bob c (2); lyn (1); Tornado (1)
