Previous in Forum: question?   Next in Forum: vrf a/c system
NPSH r for vertical submersible pumps
01/19/2010 5:35 AM
Can anyone pls. tell me what is the NPSHr for a vertical type submersible pump? Is it similar to the normal external centrifugal pumps? Or for submersible pumps only minimum submergence need to be investigated?
Thanks,
Shahnawaz
Re: NPSH r for vertical submersible pumps
01/19/2010 6:24 AM
Dah! It depends on the pump. Submergence is the term.
Irrigation Water Pumps
Good Answers: 137
01/20/2010 5:15 AM
Strictly speaking, it's the same situation as a normal centrifugal pump, there is an NPSHr figure (depending on flow) which the pump manufacturer can give you, and need to ensure NPSH available is higher. But in practice, in most situations you don't need to bother. NPSHr is typically 3 - 4m, and if your pump is just submerged you've got about 10m NPSHa.
Exceptions are if it's handling hot water, or the atmospheric pressure on the liquid surface is less than normal, as either of these reduces the NPSHa.
Could be more important to get the sump design right, to avoid vortexing.
Cheers..........Codey
04/04/2013 5:18 AM
Dear friend,
The pump should be totally submerged, in the fluid/liquid to be pumped. Hence no question of NPSHr. OTHERWISE PUMP CANNOT WORK.
DHAYANANDHAN.S
Codemaster (1); dhayanandhan (1); lyn (1)
