Previous in Forum: Air Mattress Changing into Weird Shapes   Next in Forum: Gear Ratios
India - Member - New Member
Text Search in SolidEdge Draft Files
01/19/2010 7:48 AM
Hello Mechites,
I am working as a design engineer. And am fresh to the field. We make electrical connectors.
In our company, we have drawings muddled up from all those decades. So I proposed a plan to standardize the process. I also wanted to create a component database where all component drawings are indexed into folders like 'Screws', 'Washers', 'Bus Bars' etc. for ready reference.
But all this exercise will need a text search engine which will help sort out the needed drawings from the mess. I found desktop search good enough for AutoCAD DWG files. There is also a software called 'Docupoint', I googled it.
But I cannot find a way to search text inside SolidEdge draft .DFT files, without opening them. I will hugely glad to anyone who can help me out as it will reduce our workload in measures of tons.
Thank You
Talaus
Incarnation of Inertia!
Good Answers: 119
Re: Text Search in SolidEdge Draft Files
01/20/2010 9:11 AM
Since dft files are proprietary binary format, you're probably going to have to do this task in 2 steps. 1) Convert the file to dwg or dxf. 2) Search for the text.
There are some good (free and must pay) converters HERE
Or you could use a free hex editor like NEO to wade through the files.
Hooker
01/20/2010 9:47 AM
I am using for best results not only a file of any type but also any word or phrase i a text, .html, .rtf and more with quite a good performance.
try it:
baregrep.exe
Have a fine day
Register to Reply 2 comments
