Previous in Forum: vrf a/c system   Next in Forum: Text Search in SolidEdge Draft Files
53 comments
Popular Science - Weaponology - New Member Engineering Fields - Automotive Engineering - New Member Engineering Fields - Aerospace Engineering - New Member United States - Member - New Member Hobbies - Automotive Performance - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Optical Engineering - New Member
Air Mattress Changing into Weird Shapes
01/19/2010 7:33 AM
So 5 months ago, I went to Walmart and bought myself an air mattress branded as "Main Stays", made in China. I believe it is nylon, if not some other kind of plastic. It has an electric pump and is pretty convenient to fill. So all these months, it's been working well.
A week back, the thing started changing shapes. The area in which you sleep got depressed and the air just shifted to the sides causing those side to ride and bulge out, so you felt like you're lying in a pit. I removed half that air before which I inspected the undersides for any oddities and I spotted nothing. I pump it back up and it still has the same shape.
Yesterday, I got the freakiest experience when around 5:30am, the air just started shifting beneath me and I felt myself go perhaps an inch or two lower. The air on the left side of the bed completely moved to the right side making a huge tumor like bump on one side, causing the bed to look very asymmetric now. I removed all the air and pumped it back up after a few minutes and it still retained that weird shape.
Its winter here where I live and the room is maintained around 70-72 degrees I believe. Yes it is close to a heater but a good foot away from it. I thought this was due to air expansion problem. Should I leave the room window open and let it cool, then fill cool air? Or is there some additional mechanics going on inside that is causing this characteristic behavior that I can't change (is there a bladder or something in there not doing its job)? Its bugging me, so any insights to why this is happening will be welcome. I still think there is more life in the product. But I really don't want this thing blowing up in the middle of the night and taking a few walls along with it.
Ron George
Pathfinder Tags: air expansion air mattress
User-tagged by 1 user
Re: Air Mattress Changing Into Weird Shapes
01/19/2010 7:51 AM
I would guess it has internal baffles/walls/webs to keep it in shape, and that they have ruptured.
Or maybe a cat or squirrel has got inside it
01/19/2010 8:03 AM
That's what I'm thinking too now, surely there's something inside the mattress to contain air and keep shape. But any way to confirm the rupture without tearing it open? Thing costs nearly 50.00$ and I'm frustrated it should be so short lived.
Maybe its an invisible cat that's right!
Ron George
01/19/2010 10:46 PM
That's what you get for buying something made in china!!
01/20/2010 12:02 AM
I wouldn't go so far as to generalize bad outcomes from Chinese made products. For a start even the Iphone is manufactured in China. Look it up. Designed in USA, made in China. Everyone loves the damn thing to death. People are just unhappy with China because they're taking jobs. That's not a quality issue. Sure, China has had a string of bad products. I can bring up a list of equally bad engineered stuff made in USA. Ever read the book "When Technology Fails"? You need it on your bookshelf.
Ron George
12/18/2017 1:23 AM
and Iphones are garbage..
Good Answers: 25
01/20/2010 1:05 AM
Hi Ron,
Are a bachelor ? these mattresses are meant for 2 persons so that they can remain balanced.
Good Answers: 84
01/21/2013 11:40 PM
I've seen this before. You buy that particular model, inflate it, toss on linens, blankets, whatnot, climb in and go to sleep, serene in the assurance your money was well-spent.
3:14 AM and you're suddenly hurled against the far wall like a rag doll and slump to the floor in a crumpled heap. In the dim glow of the streetlight outside you see It rise up upon its virgin-vinyl hind quarters, sprouting limbs and an enormous impossibly large befanged maw. Then it roars, but only you hear it. It lunges straight at you - your only salvation that razor-sharp machete you keep by the bed just in case last week's Blue Meanies return, as promised.
Or have they, but tonight in an even more hideous guise? You swing. Miss! Swing. Miss again! In spite of its size, it is extraordinarily agile but, even so, it doesn't see that you are slowly, methodically backing it into a corner and, just as you raise that glittering blade one last time you wake up, throw on some clothes and hustle your now-deflated monstrosity back to Wally World.
Just as you were beginning to believe it was all just a Bad Dream you enter the store and see them all looking at you vacuously, through sunken, glassy eyes that have beheld unspeakable horrors and they nod, knowingly.
You, too?
Good Answers: 37
01/20/2010 1:08 AM
"I would guess it has internal baffles/walls/webs to keep it in shape, and that they have ruptured." Usually, the webs are simply folded to form a sort of flange, and those flanges are glued to the top and bottom surfaces (inside). The "glue" may be an actual adhesive, or part of the coating (used on older models based upon woven fabrics, with the flanges sewn into position), or the two parts joined by heat-welding them - the usual method today, I think. If the joint begins to fail, it almost always propagates until the section is completely free from one surface. Picking the mattress up and shaking it may give a flapping sound to confirm the now-loose web / wall. Likely, you can see on either top or bottom that the row of dimples or shallow depressed lines that used to be there are absent from the failed spot when it's inflated.
If you can't get it replaced, or your money returned, by the seller, in theory you might be able to repair it to some extent. Use a long needle and heavy thread to "tuft" the mattress with it at very low pressure. See http://www.fabricfarms.com/mm5/merchant.mvc?Screen=PROD&Product_Code=UP72&Category_Code=Tools&Store_Code=FFI for an example of the tool. Afterward, inject each penetration with an adhesive which will bond to the mattress fabric and fill the fibers of the cord. If you mark the cord at a point perhaps an inch (25mm) less than the average thickness of your mattress, that would identify the tie-off position for each exiting cord. This will give dimples or ditches roughly half an inch deep at each tufted spot; if the originals are significantly shallower or deeper, adjust length to match. You may also need to provide something better than a simple knot to terminate the cord. Sewing several times through the perimeter in line with the intended repair area, then going a couple of inches before the first tuft, would let you glue the cord to the exterior between adjacent penetrations, and you'd zig-zag all the way along to the far end before tying off again in the non-pressurized perimeter material. Both ends of each through-cord could still be knotted, but the adhesive would greatly stabilize the construction.
" Ignorance and arrogance have more in common than their last four letters. "
Good Answers: 918
01/19/2010 7:56 AM
Oh, no! Not another air-bed metamorphosis. Does it seem like it is slowly encapsulating you?
It may be a genetic variant of The Blob, so, beware. Beware!
01/19/2010 8:05 AM
Hell yeah. Thats the freakiest part. The last time it happened, I thought of the movie Paranormal Activity and jumped up awake.
Ron George
01/19/2010 11:26 AM
I bought (2) Coleman's each leak after a few weeks, I purchased one from Walmart probally a mainstays and it seems to be good, that was about 5 years ago, very happy with it.
But this guy didn't have as good as luck with his air mattress
p911
01/19/2010 12:07 PM
I remember reading somewhere (maybe The Times) that an individual's air mattress exploding caused a section of his roof to collapse and start a fire on top of that. Funny but scary.
In my case, if it is indeed a ruptured baffle (a torn liner?) to cause the the air tube in the mattress to balloon out to one side, I wonder what caused the rupture. I certainly don't recall over-pressurizing the mattress with air. I'm the only one who uses it and have been very careful with the pump.
Ron George
01/19/2010 12:24 PM
remember 2 psi of air in the mattress X surface area oh lets say 72 x 80 x 8 deep and your laying on a container of 27,900 ponds of potential energy.
And 2 psi i think is asking for it.
01/19/2010 12:55 PM
That's a good perspective. Now to only calculate how high I will fly on burst. Does mattress come with an ejection feature?
Ron George
01/20/2010 8:07 AM
I happen to design pumps for air beds and the maximum pressure is typically around 0.5 psi. The pumps are usually blowers that will stall out around that pressure.
01/21/2010 11:54 AM
ok then.....6,975 pounds.....hows that.
01/19/2010 12:29 PM
Air mattresses of this type are not typically intended for daily use.Most people would buy this thing and use it a few times over the year for guests or on camping outings.It sounds as if you have given yours several years of expected use in a very short time.
I am sure that you have not abused it,used it as a sled,flotation device,etc... But have just used it past it's expected number of uses in a lifetime.
CARPE CRUSTULORUM!
01/19/2010 12:49 PM
The product sheet clearly mentions that the item is to be used as a bed only, (which I have done and nothing more). Not a word is mentioned about its expected lifetime or whether it should only be used for such and such short term applications. I think the manufacturer hasn't been clear on that and someone could take them to task for it, if the product fails in 5 months, consisting of on ave. 6 hours of use every day. Thats only 900 hours of total use. It'd be darn good to know whether that's the round about expected limit for something that costs over 50 dollars. Keep in mind the mattress also lays over a clean carpeted floor, not a pin mine. :)
Ron George
Good Answers: 119
01/20/2010 10:30 AM
Standard heavy gauge vinyl air mattress, probably with the topside flocking. Internal ribs/tubes/baffles that keep it flat have failed. I agree with #8, you have used a temporary guest bed as primary bedding. Given the low $50 price and the source, it is surprising it has lasted this long. Without special vinyl heat sealing tools and adhesive, repair will probably be far more work than it is worth and may not last any longer than the original. I have the queen size version of this Walmart special which has survived 5 years of "guest" use. It would have been worth $50 for my application, but I lucked out and found one on clearance for $20.
Suggest you invest 2x-4x in a standard mattress or research the >10x cost of the "real?" inflatable Select Comfort system (No endorsement intended). I prefer a firm box-spring mattress and my $199 investment is still comfortable after 21 years. In general, you do get what you pay for. Wish you better luck on your next bedding purchase.
Re: Air Mattress Changing into Weird Shapes
01/19/2010 10:42 PM
Further evidence to support my theory that plastic from China is evil and they are hoping to kill us all with its toxins so they can come steal our toys!
01/20/2010 5:41 AM
Hope it doesn't burst
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
01/20/2010 6:08 AM
The Master has moved to phase 2 of testing for his evil method for eliminating humankind.
Fear not, there will be a wooshing sound, and a distracted man in a long coat introducing himself only as "Doctor" will save you.
Chaos always wins because it's better organised.
01/21/2010 9:36 AM
Have you seen the outfit that the new Doctor is to wear? They have the poor guy in a bow tie!!
CARPE CRUSTULORUM!
Good Answers: 97
01/21/2010 10:28 AM
As disharmonious as Kathy's khaki sweatband!
CRTL-Z
Good Answers: 75
01/21/2010 10:41 AM
Bet it's a clip on. Didn't Sylvester McCoy wear a bow tie?
01/21/2010 11:34 AM
No bow tie for Sylvester.
CARPE CRUSTULORUM!
01/25/2010 5:20 AM
Doctor who?
Hobbies - Fishing - Popular Science - Paleontology - New Member
Good Answers: 27
01/20/2010 6:22 AM
Buy a Sevylor air mattress from Cabelas. Made of rubber.
Prophet Freddy has the answer!
01/20/2010 7:47 AM
Mmmmmmmmmmm rubber
Good Answers: 75
01/20/2010 7:54 AM
<swings bucket of cold water>
Thought you prepurred silk....?
Good Answers: 27
01/20/2010 1:43 PM
Us colonials prefer to prepair under silk
Good Answers: 75
01/21/2010 4:22 AM
Of course "prefurred" would have worked better.
I should have been prepared......but Del's such a purrer
Good Answers: 27
01/21/2010 8:52 AM
but .... but ......then we'd have to refur Del..........
Good Answers: 75
01/21/2010 10:39 AM
Don't you think Mrs Cat would appreciated a refurbished Del ?
Perhaps in something more practical than pure white...and machine washable
Or did you mean refur Del to a higher authority?
Good Answers: 27
01/21/2010 1:31 PM
I think Del is purrfectly capable of dipping his own toes in the Ganges without any refural...........
Mrs. Cat keeps him so I guess he's learned to use the door...............
Good Answers: 27
01/20/2010 8:47 AM
Ya...I used to rubber too...................still do on occasion...........
Good Answers: 97
01/20/2010 11:42 AM
It is a fact that the Chinese use recycled blow-up dolls to manufacture air mattresses.
Who know where that thing has been!
CRTL-Z
Good Answers: 27
01/20/2010 1:46 PM
Heck..you can still see the patches melded in..........
Good Answers: 97
01/20/2010 2:04 PM
Old age makes things change into weird shapes!
CRTL-Z
Good Answers: 27
01/20/2010 2:10 PM
It's just a question of finding ones' Nietzche..........
01/25/2010 5:22 AM
Quite so.
01/20/2010 9:42 AM
If you still have your receipt maybe Wal-Mart would exchange it. It sounds like it is defective to me and you haven't had it a year, right?
Always use protection.
Hobbies - Fishing - Zoomer
01/20/2010 9:51 AM
Did the bulge occur on the side toward the heater? If so, the heat, while not excessive, may have caused that side of the mattress to soften enough to stretch. The thinner it gets, the weaker it is, hence more stretching occurs. (That's why it is much harder to start blowing up a balloon than to add air once it's started.)
While I have not tried the Sevylor air mattresses, I can attest to Sevylor rubber boats (actually canvas vinyl). I have had one for 13 years that I bought used. It has seen hard use with my 3 kids and several others, over rocks and sticks, fishing trips, etc. I have fixed numerous punctures with some stuff called VLP (Vinyl Liquid Patch). The stuff seals well, is stronger than the original fabric, is easy to use, and lasts forever. The rubber boat just keeps going. If their air mattresses work as well, then they should last many years.
When in doubt, do it the right way.
01/20/2010 9:11 PM
Well the heater is about 2 foot away from the rear portion of the bed, so its not even against the sides. The bulge occurred at the right side, so definitely seems a liner/baffle ruptured there.
The bright side about this whole affair is that I think I now have a couch
Ron George
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
01/21/2010 2:47 AM
sew a special and sturdy bedsheet or enclosure for it, made of strong fabric (perhaps denim or even nylon netting material), just a bit smaller than its full-blown dimensions, stuff in the deflated bed, and inflate.
voila! your bed is back in form.
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
Good Answers: 37
01/21/2010 8:12 AM
What will prevent top & bottom of "special enclosure" from bulging just like mattress? The mattress HAD internal pieces in tension to prevent this, but your fabric bag will not. Experiment: put a cloth bag around a toy balloon, inflate, and see what happens! Lots of stuff sold in netting bags (here in USA, and probably there, too) so easy to do.
Good Answers: 58
01/23/2010 2:03 AM
"Experiment: put a cloth bag around a toy balloon, inflate, and see what happens!"
it's like your car tires with the exterior dictating the shape, and not the interior!
1. if fabric is stronger than balloon, the shape will be that of the fabric (like a pillow);
2. if fabric is weak and stretchable (like a woman's stocking), the shape will be that of the balloon's.
you can use canvass cloth, or double-layer your denim. I can't imagine the balloon's shape still prevailing over such restrictions, so long as the container is smaller than the balloon. there's no way it can deform its container.
I've got an additional idea. put the whole thing (balloon in it's fabric case) in a wooden box or cradle, and inflate it there. *that* should fix it.
Good Answers: 37
01/23/2010 3:38 AM
So, if the fabric is stiff enough in bending that it can prevent bulging, you can contain the air mattress - but you will have a sleeping place no more comfortable than the floor itself, regardless of whether the mattress is inside the structure, and regardless of whether it is inflated or not. Hardly a solution!
In order to comprehend how easily a pressurized bag will bulge, think about the fabric air-jacks used by rescue crews to lift cars and trucks with modest air pressure. At higher pressures, metal structures can be hydroformed - it's used to make closed-section frame rails for cars, so the stiffness can be quite high, and still be overcome by internal pressure. The shape of a pressurized fabric bag will be dictated by tensile strength of its fibers, and the bending strength of those fibers will provide no more than a secondary modification. Hot air balloons with quite low internal pressures are naturally globular in shape; to get the fanciful shapes sometimes seen, they use multiple separate compartments, and/or place INTERNAL tension elements where they can limit spreading. The air mattress had such internal tension elements for the identical reason; their failure lead to the "weird shapes" that started this thread.
The fabric used to make large sails on boats is of VERY high strength, and the pressure (force per unit area) is low, yet they deform [granted, they are permitted to do so by design, to some extent, to obtain airfoil shapes, and to limit in-sheet tension - but no practical material could keep them flat if that were the design goal!].
Good Answers: 58
01/23/2010 4:49 AM
"The fabric used to make large sails on boats is of VERY high strength, and the pressure (force per unit area) is low, yet they deform [granted, they are permitted to do so by design, to some extent, to obtain airfoil shapes, and to limit in-sheet tension - but no practical material could keep them flat if that were the design goal!]."
I don't think I mentioned that the fabric case would result to a flat air-bed surface. that would never be attainable with an air bed, in the first place. the moment a weight is placed on top of it, the surface curves in to give in to the weight.
Undoubtedly a fabric case would reduce "bounceability" of the bed, but I don't believe it will be the same as lying on the floor, either.
OP simply wanted to remove the uneven bulging of his airbed, and a fabric case, IMO could do it. OP hasn't come back with his comments, either.
Good Answers: 37
01/23/2010 10:02 AM
"I don't think I mentioned that the fabric case would result to a flat air-bed surface. that would never be attainable with an air bed, in the first place." Good thing, too, since it is not true. PLEASE actually try the experiment! A large plastic bag (they're usually flat, if the bottom seal goes all the way across instead of being gathered like some trash can liners, and you can roll the top & tape it to define a pillow shape) three feet wide and six feet long will do [1 meter x 2 meters]. See what its natural shape is when inflated alone; place it inside a strong fabric bag, and inflate again. No bag handy? how about a single-wall cardboard box - that is stiffer than any ordinary fabric bag. Geez - why didn't that work? Because the fabric's elements are working in tension, NOT bending! Even corrugated cardboard, DESIGNED to withstand bending loads, can be deformed by modest pressure over such a large area. And that's well past a comfortable stiffness for sleeping upon. 0.5 psi was mentioned; over 3 x 6 feet, that's 1300 pounds (Think of the shape of the bottom of such a box simply supported only at its edges, and with 589 kilograms of sand in it...)
Yes, 1/4" plate steel would work better, as has been pointed out.
01/23/2010 3:47 AM
Ha, use 1/4" steel plate...that'll hold the sucker in shape
01/25/2010 5:19 AM
Recycle it and buy a KrisDelTM one as a replacement (usual disclaimer).
09/17/2010 9:48 AM
the same thing happened to me last night, hence the reason why i'm even looking into this. at around 2 am the bed started to thump and the air moved and made bulges on the sides. this on top of a power outage made for a freaky experience.
Register to Reply 53 comments
Anonymous Hero (1); Anonymous Poster (2); Duckinthepond (7); English Rose (5); europium (1); Hawk2222 (1); Keywalker (1); langyaw (3); mjb1962853 (1); not so smart (3); Pajama (1); phoenix911 (3); PWSlack (3); Randall (1); rcapper (1); Ron (4); Ron George (7); suresh sharma (1); Unredundant (3); user-deleted-1105 (3); Zoomer (1)
