I have on the repair bench a pcb that is driving me nuts.
It is a driver board for a large transistor with its own isolated SMPS. It is part of an inverter run from a 385V battery to provide 40kW 3Ph power to a yacht. I have twelve of these units to check/ repair. One of the boards has a fault that I cannot understand. The SMPS provides an input of about 22kHz to an isolating transformer. I have both a Both a known good unit and the faulty unit running on the test rig at the same time. Both can be adjusted to the same voltage with the same waveform at the input to the transformer. The outputs of both units coincide as expected.
Now is the bit I cannot fathom. After the simple 1/2 wave rectification the voltage on the bad pcb is 3V down compared to the spec and the good board, even thought the O/P of the transformer is correct. The current being delivered is about 20mA in the +14V line and 10 mA in the -8V line, even less when the drive signal is off. the duff unit draws about 25% more mA than the good unit when the drive signal is present and about 25% less than the good pcb in standby.
Why should I get this drop across the diodes D7 & D8? they are good, I've replaced them anyway, same result. (were BYV95C, now IN4007)
I hope someone out there has some ideas because I'm stumped!
Regards
Chas
