We have a Sump Tank, which is basically meant for collecting both Open Drain and Close Drain systems fluids( The fluid is basically Formation water+ Hydrocarbon Liquid+Sea water). we are currently going for an externally mounted Pump to completely drain this tank by a pump which should take the liquid back to the suction Manifold of our Multiphase Pump @ a flow of 5m3/hr and a pressure of 32 bar. What kind of a pump can i use in this case?. Is Double diaphragm type pumps not to be used in open drain applications?, if so what is the reason behind it?.
We can't go for a tank mounted pump since the tank is not adequate to go for any modification or create any new nozzles for pump fixing..
Please advise me the best suitable pump for this application
