Previous in Forum: The Role of a Machinist...   Next in Forum: Cpk When Tolerance is Tight
Powder Coating / Teflon Coating /Anodizing on Aluminium Casting
01/20/2010 4:22 AM
Dear All,
It is observed that some kind of White powder comes out of the coating on the Aluminium Sand Casted part after a few months.
I have the sand casted samples on which black powder coating & Black Anodizing is done. But after few months it is observed that white powder comes out of both samples. What should be the specific reason behind this?
Now i am going to try Teflon Coating, will it serve the solution?
Good Answers: 918
Re: Powder Coating / Teflon Coating /Anodizing on Aluminium Casting
01/20/2010 8:14 AM
Talk to your casting company and ask them. It sounds like some chemicals or parts of the casting process are leeching out of the aluminum, but the casting company should be able to tell you exactly what is happing.
01/20/2010 9:46 AM
The Hero is right. You and your supplier SHOULD both be concerned about the quality of your castings. You are partners in this. If they don't care, change vendors!
Does your part specification address surface contamination? Are your parts the only ones affected? I don't believe changing coatings will solve the problem.
Do uncoated parts display this condition, too? You could go to the expense of having the powder analyzed.
01/21/2010 12:17 AM
It was my experience that when I attempted colour anodizing of alloy aluminum the results were very unsatisfactory. On pure aluminum the results were very good. Alloying elements of the part seem to play an important role in the surface quality. Also the fastness of the colour largely depends on the quality of the dye. Instead of colour anodizing I would suggest the use of Chromic Acid anodising followed by black painting. For excellent long lasting quality epoxy based stoving enamel paint will be ideal.
01/21/2010 12:27 AM
dear all,
Thank you for your valuable feedback.
If anybody have different opinion, please suggest.
01/21/2010 3:17 AM
Please read relevant chapters of 'Anodising and Surface Finishing of Aluminum' by Wernick and Pinner.
http://www.amazon.com/Surface-Treatment-Finishing-Aluminum-Alloys/dp/0904477096/ref=sr_1_2/188-9653076-9207503?ie=UTF8&s=books&qid=1264061786&sr=1-2
bioramani
Good Answers: 94
01/21/2010 12:05 PM
Have a look at this recent thread, some of the comments there may be useful.
Register to Reply 6 comments
Anonymous Hero (1); bioramani (1); krishnan.ng (1); lyn (1); Nigh (1); RAHUL JADHAV (1)
