Here my question. I have a part with a +/- tolerance of 6 microns (.000236") and the best Cpk we can get is .47 My question is should Cpk be used, is it a good measure when the tolerance is tigher then any known machine's accuracy?
I mean, none of the parts are out of tolerance, but the Cpk sucks.
Long ago I once thought that if my Cpk was less then 1.33 then I had to do more inspection to assure that my parts met the print, but today management says I can't run unless I have 1.33 or better.
Thoughts?
