Previous in Forum: Transformer Turn Ratio (TTR) Testing   Next in Forum: Conversion Kits for Gas Generators
Cable Lug Selection
01/20/2010 5:42 AM
How to select type of lug for any power application
Standard, Heavy duty, Long palm or Long barrel lugs?
Good Answers: 244
Re: Cable Lug Selection
01/22/2010 7:42 PM
Heavy Duty – It provides larger contact area and used for heavy duty (continuous) loads
Long barrels – It provides additional contact area and mechanical strength, ideally used for the area of vibration and also for continuous loads such as industrial, oil rig, mining, welding and transportation electrical termination applications
Standard and Short Barrels – used for non-continuous loads and in non-vibration area, ideally for confined areas
Inspection Window – used for the provision of inspection to confirm the conductor entered to the end of the barrel
- MS
Reply to Forum Thread
