i already done by using AISI1040 medium carbon steel... 1stly i heating 14 specimens in a furnace to austenitizing temperature 870 C for 1/2 hour. Then quenching in oil quenching medium..after that i re-heat the specimen for tempering process one by one because i want to make comparison at different tempering temperature but in same tempering time..Tempering temperature start at 100 C,150 C, 200 C,250 C....until 750 C.. but tempering time is same which is 1 hour.
Then the problem is why when i do tensile test, the maximum load is increases. The 1st specimen max load is 50.Mpa..2nd is 100..Mpa.3rd is 147Mpa and so on..and for your info UTM machine is only can do till 250Mpa and i have to stop the experiment due to this case..my question is why the max load increase when the tempering temperature is increase..it is suppose max load decrease while tempering temperature increase...tempering suppose reduced the hardness and increase ductility but why i get those result...plss help me..
