Previous in Forum: ASME 831.3 Pipes and Severe Cyclic Conditions   Next in Forum: Testing a Neck Strap
Eddy Current Testing and Ultrasonic Testing of Steel Bars
01/20/2010 12:41 PM
Could some one suggest best possible NDT test method of Steel Bars online in a Bar rolling mill to detect sub-surface defects. You may also suggest reputed suppliers and any experience on these.
SK Hegde
Re: Eddy Current Testing and Ultrasonic Testing of Steel Bars
01/20/2010 10:47 PM
If the bars are going thru a thermal change - infrared cameras may see a defect of a size and depth. The velocity that the inspection will be performed at is also needed to be described, where in the process and what changes is the material going thru will help to get better definition and answers to your question.
I have a chart assembled by NASA where they did comparitive testing between infrared, ultrasound, and other methods on non-ferrous materials, but the technology is the same.
"I believe we are masters of our lives - we hold all the cards and it is up to us to use them right." Vesna Vulova - survived 33,000ft fall
02/22/2010 8:09 AM
These are steel bars of various chemistry normally low alloy and plain carbon steels, coming out of Bar rolling mill at higher temperature of say 500 to 750Deg c or after cooling to room temparature.
We want to check sub-surface defects as well as internal defects .
SK Hegde
Register to Reply 2 comments
