Steel Column Pipes is specified to be of 8", API J55, SCH80. Threaded 8 round long, the column pipes will be used inside deep water wells with a submersible pumps. After contacting some of the pipes manufacturers they stated that all tubes fabricated as per API J55, are used as pipes if the size is less than 4", and used as casing if the size is more that 4". this raised up the issue of the difference between PIPES and Casing , so my concern is that if we can use the casing as a pipe , more specifically , if we can use API J55 8" that is considered as casing to use it as Column pipes ??
