Previous in Forum: Pipe and Casing   Next in Forum: Piping and Circular Cross Sections
Maximum Air Thurst From a Simple Turbine/Blower
01/21/2010 2:26 AM
What could be the approximate maximum air thrust in lbs one could expect from a simple turbine/blower powered by a 1hp petrol engine with a max speed of 7000 rpm.
The blower /turbine would be have to be fairly simple from plastic similar to the common garden leaf blower that is available.
Pathfinder Tags: turbine/blower thrust
Re: tim45
01/21/2010 2:41 AM
..... "Based on what we have seen, you ought to have a better appreciation for why it is preferable to compare jet engines in terms of thrust rather than power and propeller-driven engines in terms of power rather than thrust. While the opposite can be done, the process of converting between power and thrust requires us to know or assume additional information that is usually difficult or awkward to estimate."
http://www.aerospaceweb.org/question/propulsion/q0195.shtml
Re: tim45
01/21/2010 7:06 AM
It sounds as though the original poster needs to carry out some experimentation on 1hp-rated leaf blowers in order to find out....
Good Answers: 247
Re: Maximum Air Thurst From a Simple Turbine/Blower
01/22/2010 1:50 AM
Mine is about 1hp, and produces about 1-2 lb, I'd estimate.
01/22/2010 2:07 PM
Many thanks-thats all I need to know at present as I was hoping it woud be much more and ure reply tells me that my project would be a no go before I even start.
Register to Reply 4 comments
Anonymous Poster (1); Blink (1); PWSlack (1); tim45 (1)
