Been looking around at linear motion products with lots of lifecycle info found... but nothing much on how to size the actual rail as a starting point.
My application involves a vertical 2.5m travel carrying a 1m horizontal travel. Call it Z-Y I guess, or a lifting system. Both driven. Up to 50 kg on the end of the y arm.
Had in mind to use drylin system with anodized alu full round shaft & bearings for cost & life etc. I understand the 2:1 ratio for Z bearing spacing, so 500mm pillow block spacing & total Z shaft length now 3m for 2.5m travel.
But, how do I decide how to size the shaft dia ? Naturally smallest dia = lowest cost, but also = biggest bend. Anybody can grab 2" & pay more than needed, but that's not ENGINEERING is it. Even wih young's modulus calcs etc we can see expected deflection from stress, but how much is acceptable in these systems ?
Eagerly awaiting any thoughts, thanks !
