Previous in Forum: Video Measurement Software   Next in Forum: Problems with Packard Bell Easynote R4622
How to Make a Bootable XP CD
01/20/2010 5:42 PM
I am having a Window XP SP-2 setup CD. I want to make a copy of the same bootable CD with Nero 7 How to perform this task? (Actually I have made a copy of the original CD in usual way but it is not bootable)
Thanks
Pathfinder Tags: Bootable CD
Good Answers: 38
Re: How to make a bootable XP CD
01/21/2010 8:57 AM
Not familiar with nero, but there should be a checkbox in the program to make the disk autoboot. If the disk is an image, then you should uncheck the "make disk bootable" since it may already have the properties to make it auto boot which may cause a conflict. Once this is done you need to change the settings in your setup to boot from CD first. Otherwise it will start from HD with original OS.
Hope this helps.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Good Answers: 97
Re: How to Make a Bootable XP CD
01/21/2010 11:43 PM
Windows XP Embedded SP2 Feature Pack 2007 How to Create a Bootable CD-ROM
http://msdn.microsoft.com/en-us/library/ms932879(WinEmbedded.5).aspx
Engineering Fields - Mechanical Engineering - Member Engineering Fields - Manufacturing Engineering - Member
Location: Honeydew, South Africa, 26° 04' 50" Lat, 27° 54' 59" Long
01/22/2010 2:36 AM
I hope this is for backup only. Use clonecd.
Make The Most Of It.
02/08/2010 4:57 AM
You need to create an ISO image of the setup-CD, then use Nero 7 to burn it. Use the slowest burn speed available!
Welcome to the ISO Recorder download page:
isorecorder.alexfeinman.com/isorecorder.htm
ISORecorder V2 - for Windows XP SP2/SP3 and Windows 2003 (including 64-bit OS):
isorecorder.alexfeinman.com/v2.htm
avid0g
Register to Reply 4 comments
avid0g (1); bwire (1); charsley99 (1); Conrads (1)
