Previous in Forum: Dyn11   Next in Forum: DC to DC Converter
Secondary Current
01/21/2010 5:00 AM
I have a toroidal type transformer primary voltage is 415V 2 phase and secondary is 230V, 1.2KVA, how can I calculate the maximum load current in secondary
Re: Secondary current
01/21/2010 5:41 AM
Divide the load kVA by the secondary voltage.
Re: Secondary Current
01/22/2010 12:52 AM
The max load current for the secondary is 5.2 amps
United Kingdom - Member - Hobbies - HAM Radio - G7TSP Engineering Fields - Electrical Engineering -
01/22/2010 3:17 AM
As above then eat up your alphabetti spaghetti on toast.
01/22/2010 4:28 AM
Dear all,
What does "2 phase" mean?
If both primary and secondary are single phase 2 wire, the gentlemen above is all correct.
Regards
Akihito Shigeno @ JGC-Indonesia
01/23/2010 7:41 AM
In my appreciation of 2 phase it is a way of of pointing to 2 phases of a 3 phase system,this differentiates it from a phase and neutral supply.
01/22/2010 5:56 AM
compute the primary current and use the primary nd secundry voltage as ur turn ratio to arrive at the secondry current. Note the principles as it concerns current.
Dickson. Abuja Nigeria
There is peace in silence and achievement in plans.
01/22/2010 12:18 PM
all the answers are correct. below is something that'll be helpful for you...
the s above stands for "secondary" and the p for "primary"
E pur si muove -- Galileo
Register to Reply 7 comments
Akihito Shigeno (1); Dickson (1); FLIPFLOP (1); garth (1); Joe Sparky (1); Lemmy70 (1); PWSlack (1)
