Previous in Forum: DC to DC Converter   Next in Forum: Conductors in Overhead Lines
Transformer Testing
01/22/2010 3:47 AM
which tests should be taken before commissioning transformer? please explain in brief with result values.
Re: transformer testing
01/22/2010 6:38 AM
They will be in the manufacturer's information supplied with the transformer.
Re: Transformer Testing
01/24/2010 9:26 AM
If ur convinced of the factory check for oil, open and short cct. test. U can make do with following test or check during commissioning of the tranformer. Insullation resistance test, polarity and test for earth electrode resistance.The HV and LV cables must also be tested since they can also be faulty.
Dickson. Abuja, Nigeria.
There is peace in silence and achievement in plans.
01/24/2010 1:58 PM
This is not possible as it depends on the transformer and application. Refer to the local electrical standards and transformer maintenance standards applicable to your transformer, application and country for your answer. If in doubt get professional assistance or consult the transformer manufacturer.
01/25/2010 10:09 AM
result values means permissible limits for perticular test results.
Register to Reply 4 comments
Anonymous Poster (1); Dickson (1); jack of all trades (1); PWSlack (1)
