Previous in Forum: Sudden Power Failures on Lift VVVF Control Drives   Next in Forum: Neutral on Earth Bar
Earth Fault Current
01/22/2010 9:03 AM
How can calculate earth fault current?
Friend of CR4
Re: Earth fault current
01/22/2010 9:05 AM
Search the site:
http://cr4.globalspec.com/search/sitesearch?do=show&sort=textmatchrank&srch=Earth%20fault%20current&order=asc
The same question has been asked and answered many times.
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
Re: Earth Fault Current
01/22/2010 6:37 PM
Saidussadat
We often have confusion when a reference is made to earth. Do you actually mean earth(the dirt) or do you mean a fault to a grounded conductor?
01/22/2010 11:34 PM
Dear friend,
There are two types of earth faults . 1. Earthe leakage fault and 2. Dedicated earth fault.
The earth fault current is also mentioned through the CBCT and connected to the ELR and through a ammeter.
Regards,]CVS Murthy
01/24/2010 9:04 AM
THE Voltage/ Impedance of the earth fault loop path. The earth fault loop path impedance includes the risistance of the metal body fault item, earth continuity conductor resistance, earthing lead resistance, earth electrode resistance, reistance of the general mass of earth, earth electrode resistance of Neutral transformer and the transformers earth continuity conductor resistance. sum all and that is ur total earth fault loop[ impedance.
Dickson Abuja Nigeria
There is peace in silence and achievement in plans.
01/28/2010 9:06 AM
PLIZ check this books coz you seem not serious. Power system byS.K MEHTA or electrical technology by Theraja. this are enegy for you
Anonymous Poster (2); Chris Leonard (1); Dickson (1); wareagle (1)
