OSR relay
an OSR relay is generally provided in oil filled link chamber between transformer main tank and cable termination box. the link chamber contains only live bus bar and tank is filled up with transformer oil. one small conservator is provided and OSR relay is fitted in link pipe between link chamber & small conservator. Why this OSR is used? Also during external fault beyond the transformer differential protection zone, the outgoing fault feeder trips as well as OSR also operates causing tripping of the transformer which is not desirable. pl. advice.
