Previous in Forum: engg drawing   Next in Forum: Using a Vacuum in a Condenser in a Thermal Power Plant
Grade in bolts
01/25/2010 8:49 AM
Grades which are written on the head of bolts like 10.9 etc means??? What does the alphabates written on the head means???
Good Answers: 183
Re: Grade in bolts
01/25/2010 10:12 AM
10.9
10 = 1/100*Ultimate strength In this case US=1000 N/mm² (10=US/100 = 1000/100=10)
9 means that yield strength is min 90% of ultimate in this case 0.9*1000=900 N/mm²
In fact values are higher as indicated in the standards since specified are minimal values.
The most used classes are 8.8/10.9 and 12.9. There are also lower classes but used only in screew for wood never in mechanical constructions.
Good Answers: 19
Re: Grade in bolts
01/25/2010 7:48 PM
Although not used in mechanical engineering, lower grades are still used in structural engineering e.g. 5.8 and 6.8.
I haven't seen 4.6 used for a long time (only back when I came out of college) but that doesn't mean to say that they don't exist still in some parts of the world.
omw7
Good Answers: 183
Re: Grade in bolts
01/26/2010 4:05 AM
Structures have a very high degree of redundancy in the bolted assemblies this is the reason to use also low grades, but the trend with bots as TC and others is to go to higher grades for different reasons one of them being the fact that a higher grade leads to a higher ratio L/d and thus offers for same preload a higher degree of reliability with respect to preload/time. Most structural assemblies bond thin parts so that a slimmer bolt is welcome.
Re: Grade in bolts
01/27/2010 9:23 AM
The similar case is for grade 8.8 and 12.9
Re: Grade in bolts
01/25/2010 12:53 PM
This may interest.
Anonymous Poster (1); nick name (2); omw7 (1); potroom (1)
You might be interested in: Bolts, Anchors, Captive Screws
