Previous in Forum: Valmet Energy Meters   Next in Forum: Zero Sequence Impadance
Converting Mechanical Pot Control (50 k ohms) to 4-20 mA Signal control
01/25/2010 12:15 PM
Hello CR4ers:
i have a current mode PWM (pulse width modulator) controller (UC2843B). (RT/CT)determines the oscillation frequency and maximum output duty cycle. A mechanical pot (50 k ohms) serves as the user interface to control the output of the controller (it changes RT).
How can i substitute the mechanical pot for a 4-20 mA current loop input to control RT ???
Any ideas would be appreciated.
Cheers!
Good Answers: 804
Re: from mechanical pot control (50 k ohms) to 4-20 mA signal control
01/25/2010 12:44 PM
The easiest solution is to buy what is called a "signal converter" (or sometimes called a signal conditioner), a small device that will accept your 4-20ma current loop signal and convert it to a variable voltage. The input pot that you have is actually providing a variable input voltage signal, either 0-5V or 0-10VDC, which the pot is lowering by increasing the resistance. First thing you will need to do is determine which one it is using, then you can select a signal converter.
Good Answers: 29
01/25/2010 12:55 PM
Here's some more info on that idea.
http://focus.ti.com/lit/an/sboa023/sboa023.pdf
Good luck!
Re: Converting Mechanical Pot Control (50 k ohms) to 4-20 mA Signal control
01/26/2010 6:20 AM
From Tim Hawley Master Mech.
Hello Guest,
Disconnect one wire from the current mechanical pot and check the voltage across the two (2) wire connections. If it is 12 Volts, you are currently using a measuring range of 0-12 volts dc or 0 to .24 mAmps. E/R=I
Some converters have an adjustable potentiometer on the board for zero adjustment.
Make sure the wires you use are twisted for good isolated signal transmission.
Find a converter interface board to convert current to voltage and use an isolated power supply that is very stable. See last link for interface boards. The first 2 links are FYI only.
Check these links for more details,
http://celesco.com/faq/420.htm
http://zone.ni.com/devzone/cda/tut/p/id/6940
Let me know if you need more help.
Best Regards,
Tim
01/29/2010 6:05 PM
i am review the various recommendations. I will keep you posted.
thank you for your responses!
Anonymous Poster (2); JRaef (1); RDGRNR (1)
