Previous in Forum: Wiring a Linear Pot for a Power Supply   Next in Forum: Current Transformer
Converting a Ceiling Fan into a Generator
01/25/2010 9:57 PM
I'm no Edison but trying to build this thing anyway.... I'm trying to build the ceiling fan wind generator found on the YouTube link below. Problem is, the guy explaining the process leaves out a few steps and I can't connect the dots, those being... which wires do I connect the bridge rectifier to and which B/R do I use? He gives two examples of the B/R.
I have a total of 4 wires coming out of my fan connecting to the two coils. I'm guessing one is the beginning of one winding and one is the end of the same winding? (X2 coil sets)??? I want to accomplish 2 things. (1) run lights just when the wind blows and (2) charge batteries to run lights even w/o wind. (3) How do I hook up for a dump load?
Can someone help me connect the dots? Drawings would be best is possible, the simpler the better. 1-7 videos but #5-6 describes the bridge rectifier. http://www.youtube.com/watch?v=vf923InYeH8&feature=related
PART 1 HOW TO CEILING FAN WIND TURBINE
Thank you..
NotEinstein
Re: Converting a Ceiling Fan into a Generator
01/27/2010 1:16 AM
the charging system must use wind to blow the gen. i don't understand where you get energy to charge battery when it without wind blowing?.. it's always charge whenever the wind is blow and your light must on any time you need to... if it's very low wind or no wind you will get the less power from wind... but the more power that you use to light on will out from battery if it's windy while you turn your lamp.. the power will seperate in to way to charge batt. and glow your lamp...
sorry that i am not clever in english because it not my country languge so i just try to explain!
01/27/2010 8:29 PM
Thanks for your input. The lights are just for decoration.
NotEinstein
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
01/27/2010 2:36 AM
please follow this thread.
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
01/27/2010 4:21 AM
Although its possible to do, there are several possible drawbacks:-
1) very little output most of the time, OK for charging mobile phones maybe...
2) Bearings were not designed to work outside in any weather, rust will quickly become a problem....as will corrosion on many other parts....
3) if it was originally designed to run on AC (and its not a "universal" motor), you need some really good help as making an Alternator from an AC motor is not as easy as many think. A DC motor is far easier, an old stepper motor (one that "cogs") is also a good idea.....and gives an AC output that can be rectified to make "lumpy" DC....
I still wish you well in your endeavour.....
01/27/2010 8:34 PM
Thanks for your input. The generator would be lighting lights that are for decoration anyway. All the other stuff you mentioned I can work around. I'm interested in finding solutions to my questions. I know stepper motors will work but I have a different aim.
Thanks again
NotEinstein
01/27/2010 9:17 AM
There are people out on the inet that have used old drum brake style wheel hubs to do this. In any case wind speed vs rpm will be the problem. I have an old wind generator off of a sailboat. I put two three-vane hubs on it and it became around 50% more effective. I think around 10 or 12 vanes or blades would be most efficient with low wind speed without sacrificing high speed effectiveness.
Register to Reply 6 comments
Andy Germany (1); Anonymous Poster (2); langyaw (1); NotEinstein (2)
You might be interested in: Ceiling Fans, Wind Turbines, Ceiling Tiles and Panels
