Previous in Forum: Differences Between Bolts and Studs   Next in Forum: Calculating Fuel Consumption
Zirconium Welding
01/26/2010 11:46 PM
dear all...
i have working on fabrication of alloy material now,
we are processing for welding test of zirconium material for a time, but the result still crack on welding line...
any body know to tell me how the process of zirconium weld joint.
2. is there zirconium material can joint with other material like alloy or stainless steel or carbon material
Re: Zirconium Welding
01/27/2010 10:56 PM
We uses to weld Zirconium in the reactor plants on submarines, but that technology was classified, so I could tell you but I would have to kill you!!
01/27/2010 11:47 PM
i not sure you can do
Good Answers: 120
01/27/2010 11:01 PM
Per Ardua Ad Astra
01/27/2010 11:45 PM
thank you very much, it so usefull for me
01/27/2010 11:10 PM
Welding Processes
The most common process used for zirconium welding is GTAW. Manual GTAW allows all-position welding of any configuration the torch can access. Automated GTAW usually is limited to flat or horizontal positions. Seam welding machines with copper backup bars and continuous hold-down using copper bars are common for straight joints. Tube-to-tubesheet and small pipe butt welds using automatic orbital GTAW equipment also are very common.
PAW often is used for single-pass welds up to about 3/8 in. (9 mm) thick using automated equipment, copper backing bars, and square butt weld preparations. Typically, a GTAW cover pass is used to correct underfill, and the root side may require a cosmetic fusion pass or mechanical removal of excessive drop-through.
A high-current process, such as keyhole GTAW, should be considered for repetitive welding of heavy sections. Electron beam and laser welding also are suitable.
01/28/2010 10:28 PM
thank you all
01/27/2010 11:21 PM
Hai
GTAW is the best process for your requirement, but you need to work out the following.
1. Tungsten electrode
2. Filler Wire
3. Gas
4. Polority
Register to Reply 7 comments
Anonymous Poster (1); aurizon (1); Engineering Superman (2); yanwarta (3)
