Previous in Forum: PIPES UNDER astm A510   Next in Forum: Engineers 'Can Learn From Slime'
Measuring Filter Capacitors
01/27/2010 5:00 AM
I am trying to check whether the 2 pieces of EPCOS 1-line filter feed-through capacitors are still in good condition. Description: EPCOS 1-line filter capacitor. Part Number: B85121-A-B6 Value: 0.05 mfd (Y) 25A, 250V AC 60 Hz, 440V DC Type: Feed-Through Usage: The two filter capacitors were connected as series capacitor to the input winding a Siemens Transducer Module, Model 6KA9901 EL/605. The other ends of the capacitor leads are connected to a sensor module. I am confused and do not know whether the two 1-line filter capacitors are defective. When I measured them with a SANWA CD771 Digital Multi-meter on the ohm scale, the reading is 0.000 ohms but it changes to 000.1 and stayed at 000.2 ohms. I switched the measuring to the capacitor mode and observed the reading starts from 00.40 nf and changes to OL mf (over range reading) and stayed there. I checked the capacitors on the QMAX 200, an ICFT tester and also found that the V-I trace indicated a short but its trace shifted very slightly later. I guess these filter capacitors are functioning fine but I could not know a sure and concrete method to test them. Presently I am going to buy a shunt resistor and put it across the across the transducer input and pump in the AC signal (0-150mV) from a voltage injector and measure the waveform before and after the filter capacitors that were connected in series to the winding of the transducer. Can anyone please help or comment? Am I doing the next correct thing? I would greatly appreciate your help to provide the answer to me. And I buy the beer for you. Cheers to all. Thank you,all. Rockybeer
Pathfinder Tags: FILTER CAPACITORS
Re: Measuring Filter Capacitors
01/27/2010 2:07 PM
If you want to be sure the capacitors are ok you will need to isolate them from the rest of the circuitry (likely by physically removing them) otherwise your measurements will be effected by other circuit elements (or new ones you introduce) giving you strange results or masking the fact the capacitors are in fact faulty. From your test results it sounds like you are measuring more than just the capacitor.
Try un-soldering them from the printed circuit board to measure their properties directly.
01/28/2010 1:03 AM
MEASURING FILTER CAPACITORS I have isolated the two filter capacitors totally out from the circuit during the measurement but the doubtful readings were confusions. I understand that these capacitors were introduced at the input of the shunt current transducer to prevent spurious noises or RF energy getting into it and affect the accuracy of the output readings, 0 – 10 V DC. Actually the unit I am troubleshooting is a shunt current transducer, also known as signal converter. It can be configured to convert voltage to voltage or current to voltage, etc. My engineer has suggested that I use a DC and AC voltage injectors to test the transducer. At the same time, it will also test the function of the capacitors. He suggested that I inject 0 – 150mV DC and 0 – 150mV AC into the input of the transducer and I should get the result of permanent 0V and 0 – 10 V if the transducer operates correctly. Because the transducer is configured to receive the 0 – 150mV AC signal. If the capacitor works, it is blocking the DC signal but allows the AC signal to pass through them. But I am still not getting the simple method of measuring the filter confidently. If the filter capacitor is not functioning properly, I may not even know unless I measure the waveform at both ends, before and after the filter capacitors. I am writing to the manufacturer to check whether they can help. Have a nice day, Guru.
01/28/2010 2:42 AM
There are several ways to check- the easiest way is to remove part from circuit- to check whether o/c or s/c- put analogue multimeter on suitable range- to check actual cap use cap meter- to check whether can hold charge use 500 v Megger - should charge up & hold charge- so that s/c x term = spark. Other way is using ac thru light bulb- should be bright then dim if ok- stays bright= leakage current. Any doubt- replace device- they have a finite life.
Good Answers: 12
01/31/2010 3:49 AM
The one thing I note is the term FEED THROUGH capacitor. Without going into details of the inner workings of the cap... Imagine a cylinder of a conductive metal (the case of the capacitor), with a SINGLE wire (the leads of the capacitor) which goes all the way through the cylinder and out both ends. This single wire is one plate of the cap, and the cylinder is the other plate. Thus you should always see zero (or very low) resistance across the leads at either end of the cap. If you put your ohm meter between either end of the cap and the case, you will see 0 ohms to start, but it will climb to infinity ohms. This was much easier to see when we had ohm meters with a printed scale and a needle to measure the resistance. Not these new fangled things with lit numbers on them. Actually, I would apply an ac signal to the wire, and see if I got an ac signal on the case using an oscilloscope.
Bill
02/02/2010 12:06 PM
I have also measured the capacitor with the analogue multi-meter and the reading indicated zero ohm and it stayed there indefinitely. The same result occured with another exactly the same type of capacitor. The two capacitors were in series for a shunt connected to a winding of a transformer in the transducer module. I have wrote to the manufacturer and I am waitiing for the reply. Meanwhile I am also attempting to buy the two equivalent capacitors because the present two were obsolete. Hear from me when I have the answer.
02/24/2010 4:16 AM
The manufacturer has reverted to me to buy the capacitors. It is US$65.00 each and there is a minimum order of 10 pieces. The delivery time is 8 months. My boss has sent the defective equipment to a company who specializes in repairing and re-building obsolete equipment. That is the end of the story, no clear answer to the condition of the capacitors. Thank you folks for the feedback. I greatly appreciate your kind gesture and help. Have a nice weekend ahead folks! Bye. Best Regards.
Register to Reply 6 comments
jack of all trades (1); Neil Kwyrer (1); rockybeer (3); Sciesis2 (1)
You might be interested in: Chip Capacitors, Ceramic Capacitors, Film Capacitors
