Previous in Forum: Synthetic Biology Cells Produce Light Show   Next in Forum: 12V LED Incandescent Replacement
Data Transfers Using Laser Technology
01/27/2010 4:33 PM
I meet with a LNG ship captain recently regarding the inspection of LNG carriers after their cargo has been offloaded.
He mentioned that due to the enormous heights inside the storage tank areas, that Rope Access crews regularly use an Electronic clipboard and Laser technology to transfer thickness readings from the Rope Access technician/inspectors to the surveyor at the deck level or bottom of the containers.
I would appreciate any guidance as to where I might find information about this technology and or which companies sell the instruments to utilize the technology.
Thank you
virgomarine- The only restriction to one's achievements, is the self imposed limitations on the imagination.
Re: Data Transfers Using Laser Technology
01/27/2010 6:52 PM
Ok,
You've got a guy on a rope inside a tank. And a guy somewhere else. What will the laser replace? Does the inside guy yell out some value to the outside guy? Or, is there some reason why the data is needed instantly?
Remember, it's light. It stops for almost everything except clear air.
What will the laser beam buy you?
01/27/2010 8:43 PM
I have never come across such a product you describe - portable wireless line-of-site data communications using a laser, suitable for Zone 1 (given the application of inspecting emptied gas storage vessels). How about a portable hazardous area rated wireless transmitter/receiver instead?
Can you supply more information as a quick search of the internet produced no helpful results.
01/27/2010 10:48 PM
I think that they are probably using Bluetooth for data transmittal...
01/28/2010 3:12 AM
Either that or mobile phones. The youth of today, eh?
01/28/2010 4:00 AM
Re-reading your post, I am not sure if you are referring to coating thickness, or steel plate thickness. For coating thickness, both Elcometer and Delfesko, make bluetooth gauges that can transmit data as you describe
http://www.defelsko.com/
www.elcometer.com
not sure what blue tooth gauges there are for Ultrasonic wallthickness
Good Answers: 146
01/28/2010 7:57 PM
The laser technology is probably involved in measurement rather than data transfer. Applications for assessing steel in the tanks (warpage, gap widths, etc) are probably being assessed at close range by the rope crew. http://www.keyence.ca/products/vision/laser/laser.php for example.
If there's visible laser being shot to the bottom of the tank, that is probably to document the exact height and position of the readings being taken, rather than a data transfer.
The RAT crew will be using wireless to transfer electronic clipboard data.
incus opella
Good Answers: 60
01/30/2010 11:18 AM
I have to agree with all the other posters here.
Laser would be line of site, and you would spend more time setting system up than measuring.
More likely is laser measuring then transfer data via bluetooth.
Register to Reply 7 comments
artsmith (1); jack of all trades (1); Kiwi Bill (2); lyn (1); peterg7lyq (1); PWSlack (1)
