Previous in Forum: bpvc   Next in Forum: Injection Molding with Epoxy Material
Duty of pump
01/28/2010 3:38 AM
I have one query related to the duty of pump. The type of pump is VT. While giving the specifications, the vendor for pump has mentioned the duty of pump as on and off. What does that term refer to.
Thanks
Dhanya.
Re: Duty of valve
01/28/2010 4:01 AM
Hi. By mistake i have mentioned as pump. I actually wanted to know about butterfly valve. Duty of butterfly valve on off means?
Re: Duty of valve
01/28/2010 4:28 AM
<...Duty of butterfly valve on off means?...>
Either the valve is fully open, or it is fully shut.
Re: Duty of pump
01/28/2010 1:14 PM
In my opinion, the answer is that the valve is not meant for throttling. A globe valve, for example, can be throttled to a specific GPM, whereas a butterfly is basically used for on/off isolation.
R. Turner, P.E.
Re: Duty of pump
02/01/2010 9:26 PM
Absolutely correct.
Register to Reply 4 comments
Anonymous Poster (1); dhanya (1); PWSlack (1); toughguy1 (1)
