Previous in Forum: schuko cables   Next in Forum: voltage
transformer
01/30/2010 1:42 AM
what is the appropriate ratings of generator if ur going to make a power plant
Re: transformer
01/30/2010 1:53 AM
Somewhat larger (about 1.2 x) than the sum of the loads to be powered by the generator. Same voltage and frequency as the loads require. Consider the worst case: starting the largest load when everything else is already running. That's a bit of a simplified answer to a hugely simplified question.
Re: transformer
01/30/2010 5:01 AM
I should have put a bit simpler answer - it depends on how much $ you have and ready to put up in smoke
Re: transformer
01/31/2010 10:32 AM
And this would be to power your tent, your house, your neighborhood?
1-megawatt will power about 800 hopuse holds.
Register to Reply 3 comments
Anonymous Poster (1); jmart23 (1); Tornado (1)
