Previous in Forum: Type of Mechanism in Back Hoe   Next in Forum: How to Improve Home Energy Efficiency and Reduce Costs?
9 comments
Mechanical Lock for Scissor Lift
01/26/2007 10:46 AM
Is there any mechanical lock to prevent scissor lift from descending from a top position for safety?
Good Answers: 120
Re: Mechanical Lock for Scissor Lift
01/26/2007 11:22 PM
A scissor lift can be built with safety stops that take the weight and cannot be removed unless you raise the lift a little to enable the stops to be released as they are made so you cannot release them under load or you would get a collapse.
If you go to a place that rents scissor lifts they will show you the safety features
Per Ardua Ad Astra
01/26/2007 11:41 PM
Yes.
DOGS.
01/27/2007 4:05 AM
normally the hydraulic cylinder would incorporate a counter-balance/ over-center valve to hold the pressure inside in case of a power failure. that will hold the load while working and prevent it from falling off suddenly.
Good Answers: 120
01/27/2007 6:46 AM
no, they use fixed machanical stops, or "dogs" as someone calls them, in case the cylinder cracks and the fluid pressure drops and the load drops.
Like jacking up your car, you placed blocks under the car in case the jack fails
Per Ardua Ad Astra
United States - Member - Engineering Consultant Popular Science - Evolution - Understanding
01/27/2007 10:18 AM
From all the recent posts on scissor lifts, could it be that someone is attempting to design one, bit by CR4 bit?
01/29/2007 1:20 PM
I've been wondering the same thing.
Never underestimate the power of stupid people in large groups.
01/28/2007 3:25 AM
You can use faile safe circuit for this.
01/29/2007 11:23 PM
can any one explain me the mechanism of dogs in scissor lift.Are they similar to ratchet and pawl mechanism
Good Answers: 120
01/30/2007 12:13 AM
yes, similar. In a hoist by cable or hydraulic, what happens if the hydraulic fails and the pressure drops, or if the cable breaks?? The dogs as one guy calls them, are a mechanical stop that is applied when you reach the desired lift. You apply the stop and then release the hydraulc pressure or cable, and the load is now on the mechanical stop and no failure of the hydraulics or electric cable will let the lift fall on you underneath it.
http://www.google.ca/search?hl=en&safe=off&q=jack+%2Bsafety+%2Bstop&btnG=Search
http://www.google.ca/search?hl=en&safe=off&q=hoist+%2Bsafety+&btnG=Search
Per Ardua Ad Astra
Anonymous Poster (2); aurizon (3); dkamesh11 (1); Greg G (1); JDknut (1); zichau (1)
You might be interested in: Lift Tables, Lift Stations, Linear Position Sensors
