Previous in Forum: Hydraulic Press Design and Tonnage   Next in Forum: Types of Fans
Expansion Joint in Heat exchanger
02/01/2010 4:54 AM
When it is required to provide expansion joint in heat exchanger?
Is there any code requirement / guideline as per TEMA / ASME?
Re: Expansion Joint in Heat exchanger
02/04/2010 3:10 AM
When the expansion of the shell or the tubes would be great enogh to put undue stress onto these components. Code - common sense (or possible engineering).
02/06/2010 1:18 AM
I mean at what design temperature sheel / Tube side we need to go for expansion below.
Because every time we will not going to use expansion below.
Register to Reply 2 comments
