Previous in Forum: Fire Detection for Transformers and Generators   Next in Forum: Transformers
Turkey - Member - New Member
AC Current, Generators and Conductors
02/01/2010 7:14 AM
1- What happens if we directly excite a sync. generator with a.c current?
2- do conductors' life shortens because of the current flowing on it? can we say they have unlimited service life?
jinxnao
Re: two questions
02/01/2010 7:20 AM
<...do conductors' life shortens because of the current flowing on it?...>
It depends upon how close to its melting point the applied current makes its temperature. Where terminals and other fittings are present, one might find local hot-spots. A loose terminal screw, for example, will seriously affect the condition of the conductor in the terminal, and local heating may be severe enough to destroy the conductor and the terminal. That is why BS7671 requires terminals to be accessible for maintenance.
<...can we say they have unlimited service life?...>
Say it, maybe, though it isn't necessarily true, as above.
Re: two questions
02/01/2010 7:28 AM
no i dont mean the heat effect, i just mean the flow of a current on a conductor. Just "flow" does it cause any physical effect ?(is there any special deterioration we need to know? )
jinxnao
Re: two questions
02/01/2010 8:46 AM
1. When a synchronous generator is excited with AC supply, the relative motion between the field and the stator conductor becomes zero. The induced emf will be zero as per Faraday's law and hence, the generator terminal voltage will be zero.
2. A conductor's life does not get shortened because of the current flowing in it. Of course, they can have unlimited service life with no physical deterioration as long as the conductor is carrying current well within its declared ampacity.
Register to Reply 3 comments
Electronaut (1); jinxnao (1); PWSlack (1)
