Previous in Forum: Types of Fans   Next in Forum: Booster for Ammonia Cracked Gas
Buffer Tank Sizing
02/01/2010 7:47 AM
Hi, I want to install a buffer chilled water tank for our process chiller,
Process Chiller Capacity : 230 ton.
System Chilled Water : 10 m3
is it possible or not.
If yes, what are the proper equitions to calculate the buffer tank size ?
Thank You
Re: Buffer Tank Sizing
02/02/2010 7:02 AM
Calculate the total heat load of the system
Q = m cp (Tr - Ts)
then,
V = Q / (ρ * cp * Δ T)
take care the units.
02/03/2010 7:45 AM
You are smart to think about this. A lot of people overlook buffer tanks. The buffer tank is used if the chiller system volume is too small. A small system volume will cause short cycling of the chiller. Each chiller has different requirements for minimum system volume. Start by calculating your system volume including chiller and all piping. Then consult the chiller rep.
R. Turner, P.E.
02/03/2010 11:34 PM
Thank you ,
