Previous in Forum: Motors and Motor Circuits Protection   Next in Forum: Windings for Wind Generators
Dual Voltage Motor
02/01/2010 10:16 AM
Can any one please clarify me how to make a power as well as control wiring for a dual voltage motor?
recently i came across a motor whose voltage detail in name plate was 208-230/460 V
and it was a 9lead dual voltage WYE Connection.
Re: Dual Voltage motor
02/01/2010 11:22 AM
What power rating is it? What else is on the plate?
Good Answers: 804
Re: Dual Voltage Motor
02/01/2010 11:50 AM
You will need to know a little more about your, but here is a reference for all standard winding patterns used by motor mfrs. The 208-230V issue has only to do with the range. What they do is design it for 220V +- 10%, so that covers 200-240V systems. You will only have 2 connection patterns to deal with, but you will need to know if it is Y or Delta wound. The motor nameplate should tell you.
Good Answers: 29
02/01/2010 3:13 PM
Here's a sample data tag. As was said, you need to know if your motor is wye or delta wound. If the tag on your motor looks like this you're in business. If not, let us know. Also low voltage is either the 208 or 230 and high is the 460. Be advised these are NEMA configurations. There may be differences if you're an IEC kind of guy.
02/01/2010 9:37 PM
Dear RDGRNR,
your comment is exactly right, but the thing is in low voltage terminals should i provide a 3 phase 208 - 230 V supply through transformer.
Good Answers: 29
02/02/2010 10:17 AM
The motor is configured so that you can use either voltage. High or low. Strap the motor for the existing power at your facility. No need to go to the extra expense of obtaining a xfmr. I'm thinking you might want an electrician to check your work before you flip the switch.
drajesh1985 (1); JRaef (1); PWSlack (1); RDGRNR (2)
