Previous in Forum: Computing Magic: Look Ma, No Wires!   Next in Forum: A Question of Responsibility of Actions of the Past
Domestic Waste Heat Recovery
02/02/2010 6:21 AM
In the kitchen of olden houses of Sri Lanka, there were waste heat recovey method in their chimney. This was called " Dum Messa". This was just a tray which was hung above the stove. People used this for drying food such as jack, bread fruit etc. Not only for drying but also for protecting from insects this was useful. Unfortunately, these are not popular by now due to monernization.
Is there any similar kind of systems practiced in other countries.
Re: Domestic waste heat recovery
02/02/2010 6:26 AM
In the winter I keep my walking boots on top of the gas boiler...mmmm toasty warm boots
Good Answers: 143
02/02/2010 6:36 AM
When I was first married, we lived in an older house that had a small cabinet adjacent to the stove flue for setting dough to rise. You could adjust the temperature by leaving the door ajar.
02/02/2010 6:46 AM
In the UK, many domestic heating systems operate on a balanced flue arrangement, whereby the outgoing exhaust is used to preheat the incoming cold air. The effect is that less fuel is consumed to supply the same building heating demand compared with earlier non-balanced arrangements.
The usual way of doing it is to run the two ducts concentrically, the wall between them acting as a waste heat exchanger surface. The exhaust gases are still quite hot, though not as hot as with a non-balanced flue.
A greater level of efficiency can be achieved in a condensing boiler arrangement, which is newer than the balanced flue arrangement. The temperature of the exhaust is lowered below the point where the water in it condenses, thereby keeping even more heat within the building.
Good Answers: 29
Re: Domestic Waste Heat Recovery
02/02/2010 10:36 AM
For some reason, a pot of beans on the wood stove just tastes better.
02/03/2010 5:44 AM
In the same way that bacon frying over a lof fire in the open is the best food smell ever.
Good Answers: 213
02/03/2010 10:16 AM
And nothing, but nothing, can compare to campfire coffee...
Good Answers: 213
02/03/2010 10:18 AM
Depending on the fuel used, taking too much heat out of the exhaust gas stream can prove a bit dangerous, because as the exhaust gas is cooled, one can get a build-up of deposits in the flue which can ultimately result in a chimney fire...Which is why chimney sweeps were a required workforce in days of old...
Anonymous Poster (1); cwarner7_11 (2); PWSlack (1); RDGRNR (1); TVP45 (1); user-deleted-1105 (1)
