Previous in Forum: WBGT Meter   Next in Forum: High-Temperature Valves
External Strainer
02/04/2010 9:21 AM
I am looking for an external strainer that could be used to mounted outside a hydraulic tank ( suction side). I have seen a lot of intank strainer, but not an external strainer. It will be very helpful if some one were to direct me in that. Thank you.
Good Answers: 29
Re: external strainer
02/04/2010 2:06 PM
Si vis pacem, para bellum
Good Answers: 16
Re: External Strainer
02/04/2010 6:15 PM
You would be much better off installing your filter/strainer on the fluid return to the tank as the system will not be starved for fluid as could be the case when installing any sort of restriction on the suction side of a hydraulic system.
A very good option can be found in the link previously posted, its a Spin-On filter cartridge that is cheap and easy to maintain.
If you first clean your reservoir, then install the filter on the fluid return you will be fine on most cases.
02/05/2010 1:54 AM
I am no hydraulics expert, but if the system blocks nothing works, it does not matter where you put the filter/strainer.
A strainer I would put in the suction side of the pump to catch welders helmets and I would have thought that filters should always be downstream of the pump.
Anonymous Poster (1); PMoon (1); Tim in Mexico (1)
You might be interested in: Hydraulic Repair Services, Hydraulic Cylinders
