Previous in Forum: External Strainer   Next in Forum: Air Valves
High-Temperature Valves
02/04/2010 12:45 PM
I need electronic control valve should operate 100 bar pressure, 1000'C temperature flow field - gas and it should be corrosion resistance
Re: High-Temperature Valves
02/05/2010 3:02 AM
Contact valve distributors locally. Internet search? Trade directories? Yellow Pages?
02/05/2010 8:15 AM
Agree with PWSlack. More parameters will need to be obtained for the mounting capabilities, valve installation, valve automation, control/on-off and several other catagories. Many valve companies can do a turn key product with all aspects considered.
always find time to do it right the first time or.............................
02/05/2010 11:45 AM
I do not think any of us will share the glass-ceramic technology on this site. This is high temperature application of valve material which will need development work before actually implemented. Not available in market this specialized item
Masyood
Register to Reply 3 comments
Masyood (1); PWSlack (1); TRICKYDIC (1)
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
