Previous in Forum: Centrifugal Blower Designs   Next in Forum: Slip Rings
Chimney (Stack) Data
02/05/2010 4:42 AM
i like to know about designing procedure and particular datas for chimney (stack)
Re: designing chimney datas
02/05/2010 7:19 AM
Good Answers: 19
Re: Chimney (Stack) Data
02/06/2010 12:47 PM
Does this help:
CHOOSING THE SIZE OF THE STACK
Stack draft
This is the possibility the fumes stack has of eliminating all the combustion products of a boiler without forming counter pressures. Remember the stacks must be:
• completely airtight with smooth internal surfaces.
• appropriately insulated to avoid fumes cooling too much.
• the connection between the boiler and the stack must be as short as possible, avoiding bends and long horizontal sections.
T = draft of the stack in mm column of water
h = working height of stack (net of bends and sub horizontal sections)
s.a.w. = specific air weight
s.f.w. = specific fumes weight corresponds to the average temperature taken inside the stack.
T = h x (p.s.a - p.s.f.)
Specific weight of air s.a.w. (at a pressure of 760 mmHg)
Air temperature -5 0 5 10 15 20 25 30
°C
p.s.a. (Kg/m3) 1,317 1,293 1,27 1,247 1,226 1,205 1,185 1,165
Specific weight of fumes (at a pressure of 760 mmHg)
Exhaust gas 160 180 200 220 240 260 280 300
temperature °C
p.s.f. (Kg/m3) 0,848 0,81 0,776 0,774 0,715 0,688 0,664 0,64
Example: external temperature: 5°C;
fumes temperature: 180 °C;
working height of stack: 10 m
T = 10 x (1.27 – 0.81) = 10 x 0.46 = 4.6 mm
Register to Reply 2 comments
