Previous in Forum: Trouble with Tappings   Next in Forum: Generator Problem
Electronic Filter Design
02/05/2010 4:54 AM
I want to design the filter for 3 phase diode rectifier.
suppose i have % ripple value for voltage and current now i have resistive load then how can i find the value of capacitor and inductor for particular value of ripple and for various configuration of filter like LC filter, PI filter , C filter....... ?
Re: Filter Design - Can Anyone Help???
02/05/2010 10:25 AM
I will not attempt to teach all of the fundamentals of filter design in a blog. But you should first realize what frequency you must filter down to an acceptable ripple. My other hint is that you should remember that the voltage on a capacitor is found to be:
V=Q/C → (dV/dt)=(dQ/dt)/C → dV/dt=I/C
Now if this jogged your memory so you can safely proceed, good. If this is new to you, put down the soldering iron. You can seriously hurt yourself and others working on three phase power. If this is a homework problem, you've been given a hint here to help you still do your own homework.
Re: Electronic Filter Design
02/08/2010 10:32 AM
GA Redfred.
Also for the inductor, remember that V=L*(di/dt). Aother handy thing to work with are the energy forms of the capacitor and inductor.
W=½CV2 for a a capacitor, W in Joules, C in Farads
W=½LI2 for an inductor, W in Joules, L in Henries
Good luck on your quest.
