Previous in Forum: DC to DC Converters   Next in Forum: Need recommendation for Power Supply and Speed Control for 12v DC Motor
11 comments
Popular Science - Weaponology - It is my dreams from childhood Engineering Fields - Agricultural Engineering - Now I am doing this Engineering Fields - Environmental Engineering - Its my motive to take care about
LED Driving Directly by Mains
02/05/2010 8:09 AM
Friends here i got one stuff to drive LEDs which requires variable 9Vdc to 15Vdc/1A power supply to be derive from the mains voltage of 230Vac
Any ideas?????????
Thank you in advance..
Vishal Raut
Pathfinder Tags: LED driving
Re: LED Driving directly by mains
02/05/2010 10:08 AM
This is so simple and basic (just buy a power supply ) that you must have dozens of unstated limitations. So when and if you feel like telling us that this must be a supply with a minimum efficiency of X%, able to withstand weather conditions of Y, take no more space than 0.Z m3, endure a minimum acceleration of AAA m s-2, provide remote control via BBBBBBB protocol, that costs less than MMM¢ and the MTBF is at least Q millennia. Maybe then we can help you. Or you just might want to do your own work by clicking here.
02/05/2010 11:53 PM
Dude sorrrrrrrrrry
Ok i explain my requirements in detail. as follows
1. Input voltage = 230Vac
2. Variable output voltage 9V to 15V
3. Maximum output current 1A
4. Efficiency about 90%
5. and the most important size is circular with diameter of 3cm
Vishal Raut
Australia - Member - Igor...pull the switch!!!
Good Answers: 12
Re: LED Driving Directly by Mains
02/05/2010 8:06 PM
mmmmmm.....the right stuff ...make sure you have plenty of them!
CraziestOzzy
02/05/2010 11:45 PM
@ CraziestOzzy
Yaar u r still in the old ages and still using the fire for lighting. I asked abt LEDs driving
Vishal Raut
Good Answers: 12
02/07/2010 7:23 PM
...you caught me at a crazy moment...sorry mate. SMPS is the way to go.
CraziestOzzy
02/08/2010 5:15 AM
Why?
Good Answers: 299
02/10/2010 1:20 PM
Because it costs more money than the other solutions.
02/05/2010 11:43 PM
hi you can use standard smps power packs available in the market. even the cell phone chargers can be used. you may refer circuits today or red free circuits sites for various designs on this requirement. may be a step down transformer with prim 230V AC and with a secondary rated for 15 volt ac @ 1amp, a 2 amp bridge rectifier with suitable filter circuits and a variable regulator chip LM317 can take care of your requirement. beware the LEDs are constant current devices. refer manufacturers data for LED. and fabricate a suitable power supply for the. most of the present high bright say white LEDs are rated for 3 to 3.5 Volt DC with a current of 25 to 150 mA again refer mfg data.
seetharaman
visit: http://www.national.com/mpf/LM/LM317.html#Overview
02/07/2010 11:15 AM
Sound like you want to do a power light for your power supply.
Just use a resistor to limit the current across the led to 20mA at 9Vdc.
if the supply is 9Vdc it will be brighter then when it is 15Vdc
02/07/2010 2:34 PM
Look here first:-
http://en.wikipedia.org/wiki/LED_circuit#Lighting_LEDs_on_mains
http://www.ledsmagazine.com/features/3/5/2
Also, some electronics companies can sell you a finished product.....
Some LEDs are made for 230 volts as here:-
http://www.conrad.de/ce/de/product/180837/LED-230V-WARM-WHITE-AN3231-ACRICHE/SHOP_AREA_26436
Register to Reply 11 comments
Andy Germany (2); Anonymous Poster (3); CraziestOzzy (2); Doorman (1); redfred (1); vishalraut.9 (2)
