Previous in Forum: Measureing reactive torque using Gear motor or water cooled air braking system   Next in Forum: Free training course for corrosion control of pipelines
garage gantry hoist
02/06/2010 9:13 AM
I am building a gantry hoist for my garage. If the height is 7-6'' how wide must the legs extend to ensure proper balance? Any input would be great.
Re: garage gantry hoist
02/06/2010 9:40 AM
First, let's establish the height in some recognizable units.
Is it 7 feet 6 inches?
Then, let's determine if the leg width you want is parallel or perpendicular(probably) to the axis of the hoist. If we looked at the hoist from one end would the legs resemble an A?
02/06/2010 12:27 PM
Yes, 7'-6'' is the height, and if you looked at the hoist from one end it would resemble an upside down T. To the other response, eventually i will be adding some locking casters to make it mobile. The crane will be made of 2-1/2'' square tubing with 3/16'' wall. Thanks for the responses.
02/06/2010 1:49 PM
You aren't using 2 1/2" square tubing for the horizontal member, are you? If you're going to pull a 500# engine, you'd better stack two lengths one on top of the other and weld them together.
I'd make the base the same length as the uprights. Probably gusset the joint at the upright/base.
I just stole this: this from phoenix911 on another post. It might help. I haven't looked at it
02/06/2010 2:55 PM
Thanx for the info, the horizontal member will be constructed of four 2-1/2 inchers, just making it this way because i got a bunch of it for free from a bridge job we just completed, so it won't cost me a dime, otherwise i realize this wouldn't be a very economical way of making one of these.
02/06/2010 7:29 PM
Whoa! I was gonna suggest three, but thought that with 3/16th wall tubing that'd be overkill.
Did you check out the link I stole from phoenix911?
02/07/2010 11:08 AM
I recommend that you supplement the base of the inverted "T" with tall triangular braces reaching to the ends of the legs.
avid0g
Good Answers: 114
02/06/2010 11:35 AM
I'm not sure what you mean by "gantry crane". I assume you want a lift point over the car. Does the lift point have to be on a trolley to move the lift point from side to side? Do you want wheels on the base to be able to move the lift point backwards and forwards?
Anonymous Poster (2); avid0g (1); lyn (3); passingtongreen (1)
