I forgot my password.
Don't have an account?
What is the difference between An OFF Load & ON Load Tap changing In a HV Transformer (Rating 1600KVA) & which one is better.
http://en.wikipedia.org/wiki/Tap_(transformer)
Off-Load Tap Changer: To operate this type of tap changer, the transformer has to be de-energized.
On-Load Tap Changer: The tap changer can be operated with transformer keeping energized.
The Off-Load Tap Changer is simpler and less expensive than the On-Load one but the service continuity is not maintained during the tap change.
If the system voltage fluctuates very often and the service continuity is important, the ON-Load should be the choice of selection.
The following links may be further help:
http://nptel.iitm.ac.in/courses/IIT-MADRAS/Electrical_Machines_I/pdfs/1_15.pdf
http://www05.abb.com/global/scot/scot252.nsf/veritydisplay/c1256b3c00492da6c1256ae2003f9b3e/$File/1LAA101003AAEN_Large-Distribution-Transformers.pdf
http://canteach.candu.org/library/20030803.pdf
http://cr4.globalspec.com/thread/12215
http://cr4.globalspec.com/thread/13006
- MS
In On Load, U can Tap Change with the transformer On Load.
In off load , U have to switch off transformer load load b/4 Tap changing.
Dickson
