Previous in Forum: HV Transformers and Loads   Next in Forum: Generator Controls
Inverters and Batteries
02/08/2010 11:39 AM
hey guys!!!!!! me wana to make an inverter,but im stuck with the source to that inverter,i want to knw abt ratings of battery,which i shud use as source.
i want my inverter to feed atleast one fan for 20mts.
also tell me on wat basis,v hav to choose tat battery.
padupoi
Re: inverter
02/08/2010 11:47 AM
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=retrieveTfg&tfgSearch=Y&N=4294953907&searchTerm=DC/AC Inverters (Battery Voltage)&cm_sp=Predictive_search-_-Pedictive_search-_-DC/AC Inverters (Battery Voltage)
Re: inverter
02/08/2010 11:57 AM
The total rated wattage of the fans is the minimum rated wattage of the inverter unit that must be selected for the duty. Take the total wattage of the fans and multiply by 0.33 hours (assuming "20mts" means 20 minutes run-time on the battery) to give the electrical energy needed during that time in watt-hours. Divide watt-hours by the voltage of the battery pack supplying the inverter to give a battery capacity in amp-hours. Divide by an efficiency of, oh, say 85% to give a required battery capacity upstream of the inverter. Add batteries of similar voltage wired in parallel until the amp-hour ratings of all the batteries added together exceeds the requirements.
Either that or select DC battery-driven fans instead and do away with the inverter.
Re: inverter
02/08/2010 7:49 PM
all izzz well.....but wat is the need for dividing Ah by efficiency.
padupoi
Re: inverter
02/08/2010 11:27 PM
Efficiency of the inverter - The ratio between the out put power and the input power fed to the inverter. That is the power lost in the conversion. Say your requirement is 100Watts at 110Volt to get this your inverter requires say 12 volt at 10Amps. Then the efficiency of the inverter is 100 watts / 120 watts that is 83.33%. You have to account for this loss in choosing the AH for the battery.
seetharaman
Re: Inverters and Batteries
02/09/2010 8:09 AM
To determine ur battery capacity, check ur load current and compare it with the Amp Hour capacity rating of the battery. If ur load current is 5 Amps, U will need a 60AH battery for (60/5) 12Hrs approximately. Note some energy is consumed in the transformer area that further limits the battery,s time (not considerably).
Dickson
There is peace in silence and achievement in plans.
02/09/2010 12:48 PM
switch your fan motor to a dc motor, forget trying to build an inverter.
"god gave us fuel, greed gave us gas"
Register to Reply 6 comments
ageniusforhire (1); Anonymous Poster (2); Dickson (1); padupoi (1); PWSlack (1)
You might be interested in: Battery Holders, Battery and Fuel Cell Components
