Previous in Forum: Snow and More Snow   Next in Forum: The Eleventh Square
Safety - Hazmat - New Member Technical Fields - Project Managers & Project Engineers - New Member
Woodworms
02/10/2010 2:32 PM
Dear all, I have problems with woodworms that have started destroying my wooden ceiling, could some out there advice me on the best pestcide that I can use without affecting the people in the house and my two lovely cats that stay in the house. Luyombya.
"It doesn`t make sense to hire smart people and then tell them what to do, hire smart people so they can tell you what to do."--- Steve jobs.
Hobbies - Musician - New Member APIX Pilot Plant Design Project - Member - New Member
Re: Woodworm
02/10/2010 3:33 PM
http://www.bearfortlodge.com/bearfort_lodge/2006/12/log-home-repair-restoration-replacing-chinking-and-fixing-logs-part-vi-home-brew-wood-and-log-preservative/
Try this stuff . . . made with boric acid . . . is both a preservative and insecticide . . . is biodegrable and non-toxic.
A government big enough to give you everything you want, is strong enough to take everything you have.
Re: Woodworms
02/10/2010 10:53 PM
Are you sure if they are woodworms or termits.
Good Answers: 97
Re: Woodworms
02/11/2010 1:10 AM
CO2
Re: Woodworms
02/11/2010 2:23 AM
Hi All,
Here is solution for all types of insects. "Metacid 50" is best solution on termites, woodworms, ants, cocroaches and many more. This medicine is required water as a medium. Add 5 ml in 50 Ltrs. of water and spray it on any surface or effected area. All will finished.
Re: Woodworms
02/11/2010 6:33 AM
I've had good results protecting pine from our very aggressive termites by soaking copper sulphate into the timber (can be done by repeated coverage with a paint brush).
Get as good a penetration into the timber as you can.
After this has dried, repeat using borax solution.
The borax reacts with the copper sulphate to form a fairly insoluble copper borate which, while fairly harmless to humans, seems to be very poorly tolerated by insects.
Advantage of this is it is cheap, readily applied by you and the chemicals are usually easily available.
Re: Woodworms
02/11/2010 8:39 AM
Our company provides a variety of natural ingredients to manufacturers, farmers, gardeners etc. One of them is neem oil. It has a very very long history protecting property, crops, animals and people against a variety of pests and is used in a vareity of skincare products and mosquito repellents. It is easy to use, inexpensive and has a broad range of applications. On our farm we use it on crops, horses, dogs and around the house. Our website www.pureandsimpleways.com has a good description. You could send a message via contact us with this application and will get a response from a chemist as how to best mix for this application. I am only familar with crops and horse/cow uses. Neem is not a poison. It does cause pests to lose their urge to eat and thus they die. It also stops reproduction. Available is a large amount of research from universities and government agencies. Neem is truly one of the most effective medicinal plants in the world.
Register to Reply 6 comments
Anonymous Poster (2); bwire (1); nukesub629 (1); Pure and Simple (1); sceptic (1)
