Previous in Forum: Local Surge Pressures Inside Pump House   Next in Forum: Titanium Linings
Surface Area Formula
02/11/2010 5:08 AM
90Elbow surface area calculation formula.
Re: surface area calculation formula
02/11/2010 7:44 AM
Area of a Circle
This will work for straight pipe as well as curved pipe. It does not work well on square pipe.
I made the assumption that you wanted the inside, circular area. Your question is too ambiguous to answer with intelligence.
Re: Surface Area Formula
02/12/2010 12:42 AM
D= outside cross-sectional diameter of elbow (or bend)
R = radius of center line of elbow
θ = degrees of bend of elbow
A = (πD)(2πR)(θ/360) = π2DRθ/180 ≈ 0.055 DRθ.
[You may think of this as (pipe circumference) x (swept circumference of a full circle)(fraction of circle thet the elbow is).]
Register to Reply 2 comments
