Previous in Forum: Sizing a Pump   Next in Forum: ASME Qualification for GMAW-S Welding of ASME P4 G1
12 comments
Shaft Rotation
02/11/2010 9:58 AM
I need to rotate a shaft with 400 to 900 pounds of weight on it at 4 RPM. The shaft has bearings on each end. What would be the best way to do it? Direct drive motor to the shaft? What type of Motor? How to slow it down that slow? or Should I do sprockets, again how to slow it down? Also I want to do it relatively inexpensive.
Good Answers: 58
Re: Shaft rotation
02/11/2010 10:32 AM
Hopefully the weight is balanced. If not, do what you have to to balance it. If the device has a large diameter anywhere you can put a chain around it. A few screws will serve as teeth for the chain. I would use a drill motor for the drive. It has a gear reduction, and just hold the drive sprocket in the chuck. You can get variable speed and reverse from a good drill motor, they are reasonably priced, and easily replaced.
mike k
Re: Shaft rotation
02/11/2010 3:12 PM
Good Idea never thought of that. But I am looking for more of a permanent way to rotate the shaft (unattended). Yes the load is balanced equally around the shaft. Any other ideas anyone?
Good Answers: 60
Re: Shaft rotation
02/11/2010 4:17 PM
can you describe shaft better?
i assume the shaft has load on one end?
or is load in middle with bearings at each end?
does the shaft extend beyond the bearings and if so by how much?
would drive be connected to ends or drive the middle?
Re: Shaft rotation
02/12/2010 1:37 AM
Why balancing is required while the speed is very low, 4 rpm?
To reduce to this low speed, I suggest, the first step of reduction through chine or belt drive and second step of reduction through a 'worm and worm wheel gear box' drive.
Re: Shaft Rotation
02/11/2010 6:56 PM
Not enough information. 4 RPM is slow. Can you send a picture? Do the shafts protrude through the bearings. Could you attach a gear? Check out gear motors on Google or Search GlobalSpec
Re: Shaft Rotation
02/11/2010 7:20 PM
Belt drive will be your best bet I think.
How quickly do you need to slow it down? A simple disk brake system should work.
Re: Shaft Rotation
02/12/2010 4:16 AM
have a gear box of gear ratio 60:1 and then give a gear drive with a 13 teeth gear on gear box driven shaft and 91 teeth gear on main shaft u want to rotate , you will have 4 rpm of shaft
nothing is impossible !
Re: Shaft Rotation
02/12/2010 9:02 AM
The simplist solution might be a worm gear drive.
Re: Shaft Rotation
02/12/2010 10:38 AM
It is a meat smoker that I am building. The shaft design has not been designed completely yet. The shaft has a plate on each end with holes to support shelves that run from one plate to the other. If you look at the end of the shaft the end view would kind of look like a ferris wheel, the shelves are swinging free so that they stay level at all times with the meat on them. I was planning on running the shaft out one end like a rotisserie on a barbecue. I don't know what size motor to use. The information about the gear tooth count and gear box ratio is very helpful. Is there not a way to couple the motor to the end of the shaft that would work maybe motor to gear box to shaft connect?
Re: Shaft Rotation
02/12/2010 7:31 PM
It seems to me that the simplest way would be a gearmotor with a variable power supply using a sprocket and chain. Gearmotors come many sizes. There is likely to be one to meet your needs at a reasonable price.
abcpaper (1); Anonymous Poster (3); lyn (1); mike k (1); peterg7lyq (3); Steve S. (1); tommm (1); yesyen (1)
