Previous in Forum: Plate Heat Exchangers   Next in Forum: Shaft Rotation
Sizing a Pump
02/11/2010 8:40 AM
I have an engineering problem that I dont know how to figure out. It may or may not be the right forum for this question but here goes. I have a 12.5 MM I.D. nozzle with a 6 foot hose attached that has a 3/4" I.D. What size pump (Pressure output and GPM) do I need to raise the pressure at the nozzle up to 15 psig? I would prefer to stay under 15 amps for 115Vac and can run with 230Vac up to 20 amps. Thanks a million
Re: What size pump do I need?
02/11/2010 10:42 AM
Provided your nozzle is a general purpose smooth bore 0.5 inch ID nozzle, it's discharge Q will be some 30 gpm at 15 psi nozzle pressure. I assume you speak of water at around 60 - 65 deg F. As your supply hose is only 6 ft long, it's friction losses will be negligible and not worth bothering about. So have a pump to supply around 35 gpm to a 35-36 foot head. You can run your pump on either 115 or 230 VAC... it is up to you.
Good Answers: 97
02/11/2010 12:48 PM
oznative - Beware of the US - Imperial GMP conversion possibly needed in post 1.
Good Answers: 109
Re: Sizing a Pump
02/12/2010 12:19 AM
I think you will find that most fractional pumps will deliver the 15 psi. A 1/2 hp can run on 115v and 11.5 amp and will deliver about 10 gpm on open discharge and slightly less at 15 psi. If you want higher outputs you may have to go to a higher hp and will likely need 230v. Based on your breaker of 20 amps I would not exceed 1/2 hp. The starting amps of this 1/2 hp will be momentarily about 20 amps plus. Most pump catalogs will have the curves you need. Just call any pump supplier for direction.
Hope this helps.
Re: Sizing a Pump
02/12/2010 6:38 AM
Thanks to all that responeded. I really appreciate your willingness to help. I hope that in the future I will be able to offer you all advice as well.
Sincerely
Register to Reply 4 comments
Alexander M. Berlin (1); Hendrik (1); kevinm (1); oznative (1)
